1. Re: Old photos clean-up
John Joslin Nov 2, 2009 8:48 AM (in response to bonalymac999)I doubt whether you'll get a decent result with an automated method.
Try cloning from good areas with the tool set to Darker Color mode to avoid overpainting the branches.
Clone on a layer copy to avoid destroying original pixels.
2. Re: Old photos clean-up
John Joslin Nov 2, 2009 8:53 AM (in response to bonalymac999)If you have a lot to do it would be a worthwhile investment to buy Katrin Eismann's book.
3. Re: Old photos clean-up
Zeno Bokor Nov 2, 2009 9:07 AM (in response to bonalymac999)you might be able to pull it off with a single Hue/Saturation adjustment layer by shifting the purples to a green that blends in with the rest of the image
4. Re: Old photos clean-up
bonalymac999 Nov 3, 2009 1:57 AM (in response to John Joslin)Thanks that worked well.
In this case, Darker colour did not help mon all areas since I was painting in a white colour but I maanged to get it cleaned from here.
Thnaks aslso to the other replies. It is much appreciated. Obviousyly I accept that a staing issue like this is depenedent on the actual colours involved amd the huie sat layer cganges did not worjk - in this case - I have kept a note of this tho as it will worlk in other casea I'm sure.
Thanks again
Colin
