1. Re: FrameMaker 9 stopped opening .fm files -- help?
Russ Ward Nov 2, 2009 11:35 AM (in response to Seanb_us)Sean,
I have seen this happen, but the problem did not persist through an FM restart. I don't know what the answer is, but I thought I'd at least let you know that it has been seen before.
Russ
2. Re: FrameMaker 9 stopped opening .fm files -- help?
Sheila Carlisle Nov 2, 2009 11:42 AM (in response to Seanb_us)I've seen display corruptions in FM9 that sound similar, and in my case I think they're memory-related. The effect that you describe is the same, the FM window opens blank white, and if/when the chapter does open, the icons and task bars are transparent, so I can see the desktop behind them, but the icons and menus do actually work if I put my cursor where they should be appearing.
In my case this is when working on huge files (by huge, I mean 1000+ pages filled with tables, approx 1million table cells total). This system is WinXP / SP2, 4gb RAM
3. Re: FrameMaker 9 stopped opening .fm files -- help?
Arnis Gubins Nov 2, 2009 11:54 AM (in response to Seanb_us)Sean,
It's (white screen) also been reported (and I get it too) when creating CYK PDFs. This is just temporary while the PDF is being produced, but something at the FM end is definitely triggering.
It sounds like lucky you has hit the magic combo that triggers the white screen for normal operations.
Do you have any Framescripts that run at start up or event scripts lying in wait? Have you disabled all third-party plug-ins?
4. Re: FrameMaker 9 stopped opening .fm files -- help?
Seanb_us Nov 2, 2009 12:38 PM (in response to Seanb_us)Thanks all.
These are small files, from opening the stock portrait template to opening an .fm that's maybe 50 pages.
I have nothing else running. The PC has 2GB RAM and a 3GHz Intel CPU.
Any advice to get FrameMaker working on this PC again?
Sean
5. Re: FrameMaker 9 stopped opening .fm files -- help?
Reviewer1066 Nov 2, 2009 1:35 PM (in response to Seanb_us)If you notice that when the screen goes white, the window border looks like a standard Windows window frame (that is, with blue borders), not the standard FrameMaker window frame/desktop.
This is my "theory"...
Because FrameMaker code is very old, it does not call the operating system as often as new applications do , such as Illustrator. When it is doing a time-consuming process, at some point the Windows operating system is told to draw the window frame, which it does by creating the standard frame filled with white. When Frame is finished with its long process, it then has a chance to draw its own version of the window frame; thus, the white screen with blue border disappears and the standard FrameMaker desktop/window frame displays. It is a temporary thing, but eventually goes away if one waits long enough...at least that is my experience.
Some one in an earlier post mentioned that it appears to be resource related. I recently upgraded my computer to more memory, and the white screen appears much less often, which seems to agree with the idea that it is related to available resources.
6. Re: FrameMaker 9 stopped opening .fm files -- help?
Seanb_us Nov 4, 2009 11:11 AM (in response to Reviewer1066)So ... let's say you have a PC on the corporate network. And, your antivirus solution is dispensed from a central location on that network. And, the network resource changes and your PC cannot find it, but now is always looking for that network resource.
Under such extraordinary circumstances, do you think Windows having such network issues might get in the way of FrameMaker 9 (but not FrameMaker 8) drawing its windows correctly?
Thoughts?
Sean
7. Re: FrameMaker 9 stopped opening .fm files -- help?
Sheila Carlisle Nov 4, 2009 11:34 AM (in response to Seanb_us)Maybe you could try "de-podding" the FM workspace, which makes FM use much lower amount of memory when opening files. I'll try to dig up a link resource for the way to do this, I think it was posted on one of the FM tech blogs not too long ago.
edit: here's a start: http://blogs.adobe.com/techcomm/2009/05/workspaces_in_fm9.html
8. Re: FrameMaker 9 stopped opening .fm files -- help?
Seanb_us Nov 4, 2009 11:59 AM (in response to Sheila Carlisle)Thanks all!
My solution was to rip out the hard drive, buy and install a new hard drive, install the OS all the applications and all the patches.
It worked like a charm. FrameMaker 9 is again functional.
I wish I know why it broke though, so I could provider some helpful hints about prevention.
Cheers,
Sean
