0 Replies Latest reply on Nov 2, 2009 12:44 PM by Carol L. Frampton
    [svn:fx-trunk] 11378: Rearrange exisiting TLF sources to be in the same structure as the new drop we 're about to take so that we can maintain the change history.
    Carol L. Frampton Level 2
      Revision: 11378
      Author:   cframpto@adobe.com
      Date:     2009-11-02 12:43:46 -0800 (Mon, 02 Nov 2009)
      Log Message:
      Rearrange exisiting TLF sources to be in the same structure as the new drop we're about to take so that we can maintain the change history.
      QE notes:
      Doc notes:
      Bugs:
      Reviewer:
      Tests run: checkintests, TextArea
      Is noteworthy for integration: no
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/textLayout/build.xml
      Added Paths:
          flex/sdk/trunk/frameworks/projects/textLayout/manifest.xml
          flex/sdk/trunk/frameworks/projects/textLayout/src/
          flex/sdk/trunk/frameworks/projects/textLayout/src/flash/
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/BuildInfo.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/CoreClasses.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/EditClasses.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/acc/
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/compose/
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/container/
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/container/TextContain erManager.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/debug/
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/edit/
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/edit/EditManager.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/edit/ElementRange.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/edit/IEditManager.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/edit/IMEClient.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/edit/Mark.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/edit/ParaEdit.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/edit/SelectionFormatS tate.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/edit/SelectionManager .as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/edit/TextClipboard.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/edit/TextFlowEdit.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/edit/TextScrap.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/elements/
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/events/
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/events/FlowOperationE vent.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/events/SelectionEvent .as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/external/
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/factory/
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/formats/
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/operations/
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/property/
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/tlf_internal.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/utils/
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/utils/NavigationUtil. as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/undo/
      Removed Paths:
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_conversion/
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_edit/
