2 Replies Latest reply on Nov 2, 2009 1:22 PM by thisisme138
    Quick way to check and add imports?
      Is there a way to check to see if you have missing imports and add them automatically?
      the Shift-Command-O shortcut removes all imports that aren't necessary in the file, but doesn't add them.
      Say I copy and paste a code block, but those classes that are needed aren't already imported. I would like a quick way to add those classes to the imports.
      Is that a current possibility?
        • 1. Re: Quick way to check and add imports?
          mewk Level 3
          If you paste in a block of code and are missing import statements, then when you save the file (assuming auto-build is checked), you'll get compiler errors. The easiest way, I find, to fix the import errors is to go to the line throwing an error, delete one letter from the end of a declared type and then auto complete the name (ctrl + space). Of course, this only work if the class can be found in your library or source paths.
          - e
          • 2. Re: Quick way to check and add imports?
            thisisme138 Level 1
            Not a bad way to go about it. Unless there is another shortcut that does it all automatically, I will be using that shortcut.
            -John Brown
