0 Replies Latest reply on Nov 2, 2009 1:16 PM by Carol L. Frampton
    [svn:fx-trunk] 11380: Insert another textLayout directory under projects\textLayout so the new TLF drop can be unzipped from the root and their build file should work with no modifications .
    Carol L. Frampton Level 2
      Revision: 11380
      Author:   cframpto@adobe.com
      Date:     2009-11-02 13:15:31 -0800 (Mon, 02 Nov 2009)
      Log Message:
      Insert another textLayout directory under projects\textLayout so the new TLF drop can be unzipped from the root and their build file should work with no modifications.
      QE notes:
      Doc notes:
      Bugs:
      Reviewer:
      Tests run: checkintests
      Is noteworthy for integration: no
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/textLayout/build.xml
      Added Paths:
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout/
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout/src/
      Removed Paths:
          flex/sdk/trunk/frameworks/projects/textLayout/src/
