10 Replies Latest reply on Nov 3, 2009 6:10 AM by iamfuric
    Combobox with dynamic dataProvider
    Zolotoj Level 3
      I have a very simple code:
      private function showAvailableLabels(resultXML:XML, param:Object):void
      if (resultXML.children().length() == 0)
      Alert.show("Sku " + sku.text + " not found!", "Error");
      else
      labels.dataProvider = "";
      labels.dataProvider = resultXML.availablelabels;
      labels.validateNow();
      labels.setFocus();
      labels.selectedIndex = 0;
      That code assigns different dataProvider to a combobox at the run time. I cannot get the exact pattern, but after a few times the combobox starts showing data from a previous data assignment. Do I have to refresh it somehow?
        • 1. Re: Combobox with dynamic dataProvider
          Matt Le Fevre Level 4
          a simple
          [comboboxname].dataprovider.refresh();
          command may work
          • 2. Re: Combobox with dynamic dataProvider
            Zolotoj Level 3
            Same problem.
            • 3. Re: Combobox with dynamic dataProvider
              iamfuric
              You should assign dataProvider on next refresh cicle with callLater :
              callLater(function (dp:Object):void
              {labels.dataProvider=dp},[resultXML.availablelabels]);
              • 4. Re: Combobox with dynamic dataProvider
                Zolotoj Level 3
                Nope, same ....
                • 5. Re: Combobox with dynamic dataProvider
                  paul.williams Level 4
                  No refresh / callLaters should be required. If you change the dataProvider of a ComboBox it will trigger commitProperties / updateDisplayList and refresh automatically. Use the FlexBuilder debugger or FlexSpy to inspect the contents of the ComboBox dataProvider at runtime, or provide a runnable demo of the problem.
                  • 6. Re: Combobox with dynamic dataProvider
                    Zolotoj Level 3
                    I will try to provide a workable demo, although after stripping everything out it might as well  start working.
                    I have checked incoming data and dataProvider at the run time. Both look right.
                    • 7. Re: Combobox with dynamic dataProvider
                      iamfuric Level 2
                      Hmmm,  it IS required for table , check the attached sample out ...
                      • 8. Re: Combobox with dynamic dataProvider
                        Zolotoj Level 3
                        Dont see anything attached. Sorry, I see it now.
                        • 9. Re: Combobox with dynamic dataProvider
                          Zolotoj Level 3
                          Here is a runnable demo I have put together using provided code:
                                            xmlns:s="library://ns.adobe.com/flex/spark" creationComplete="switchDataProvider()"
                                            xmlns:mx="library://ns.adobe.com/flex/halo"
                                            minWidth="1024" minHeight="768">
                               <fx:Script>
                                    <![CDATA[
                                    private var model_1:XML = <VFPData>
        <availablelabels>
        <filename>193</filename>
        <id>10</id>
        </availablelabels>
        </VFPData>
                                    private var model_2:XML = <VFPData>
        <availablelabels>
        <filename>192</filename>
        <id>9</id>
        </availablelabels>
        <availablelabels>
        <filename>160down</filename>
        <id>25</id>
        </availablelabels>
        </VFPData>
                                    private var current:XML = model_1;
                                    private function  switchDataProvider():void
                                         current = current==model_1?model_2:model_1;
                                         comboBox.dataProvider = current.availablelabels;
                               </fx:Script>
                               <mx:VBox>
                                    <mx:ComboBox id="comboBox" labelField="filename"/>
                                    <mx:Spacer height="10"/>
                                    <s:Button click="switchDataProvider()" label="Switch"/>
                               </mx:VBox>
                          </s:Application>
                          Click on the push button and check the content of the combo, you should 192 from previous data.
                          • 10. Re: Combobox with dynamic dataProvider
                            iamfuric Level 2
                            Золотой, ты бы потрудился хотя бы САМ создать демо версию...
