0 Replies Latest reply on Nov 2, 2009 3:17 PM by CoreyRLucier
    [svn:fx-trunk] 11383: Adding a flag (-enable-swc-version-filtering=false) to disable compatibility-version swc filtering on demand as it' s required by Catalyst when building their design view.
    CoreyRLucier Adobe Employee
      Revision: 11383
      Author:   clucier@adobe.com
      Date:     2009-11-02 15:17:27 -0800 (Mon, 02 Nov 2009)
      Log Message:
      Adding a flag (-enable-swc-version-filtering=false) to disable compatibility-version swc filtering on demand as it's required by Catalyst when building their design view.
      QE notes: None
      Doc notes: None
      Bugs: None
      Reviewer: Darrell
      Tests run: Checkin
      Is noteworthy for integration: Yes
      Modified Paths:
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/asdoc/AsDocAPI.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/common/CompilerConfiguration.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/MxmlConfiguration.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Compc.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Fcsh.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Mxmlc.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/Application.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/Library.java
