3 Replies Latest reply on Nov 3, 2009 8:00 AM by soupycafe
    Ah! the delights of advanced data grid!
    soupycafe
      I have a xml hierarchical advanced data grid.
      Is there a way to disable the folderIcons for the advanceddatagrid?
      Or is there a way to integrate the folderIcon actions to selected row actions?
      Right now, I have a listener for itemOpen. When one folder opens, then another one will close. However, when the user clicks on the folderIcon....it does not do this. I do not know how to access the expandeditem of the advanceddatagrid.
      Thank you for your help!
      Emma
      * Also, the fonts are being embedded by css...when you click on the folder...the fonts jump while they are being propagated. suggestions?
        • 1. Re: Ah! the delights of advanced data grid!
          soupycafe Level 1
          OK! So I was making things hard on myself.
          I had enabled a listener for openItem...instead of putting it directly on the advancedDataGrid.
          It is fantastic...
          However, it would be great to disable the treeNode Icon functionality(drop down arrows).
          I still want them to rotate upon showing their leaf extensions though.
          thank you for your help,
          Emma
          • 2. Re: Ah! the delights of advanced data grid!
            Sameer Bhatt Adobe Employee
            You can try preventing the itemOpening event.
            Create an itemOpening handler and call event.preventDefault();
            -Sameer
            • 3. Re: Ah! the delights of advanced data grid!
              soupycafe Level 1
              That is a great idea...except I am using the selectRow to use these same events.
              It seems what I need is access to the same selectedItem.
              When I click on the row, I pass through _selectedItem from the event function.
              However, it is a little bit more complicated for the drop down buttons.
              I try to get the same format with this:
              selectedItem=IHierarchicalCollectionView(adg.dataProvider).openNodes;
              but I get an [object][object]
              I found this bit of code on a site:
              import mx.collections.HierarchicalCollectionView;
              myOpenNodes:Array = new Array();
              var HierColView:HierarchicalCollectionView = HierarchicalCollectionView(myADG.dataProvider);
              for each ( var item:Object in HierColView.openNodes ) {
              myOpenNodes.push(item);
              myADG.dataProvider.openNodes = myOpenNodes;
