5 Replies Latest reply on Nov 4, 2009 6:49 AM by kglad
    duplicateMovieClip() problem
    gopal73thakkar
      hi
      in my project i am making one line graph using createEmptyMovieclip() function, and i want to add facility of making multiple copy of that graph to user and for that copy facility i am using duplicateMovieclip() function but when i execute that only parent object(Graph_mc) is copied and the child object(Line_mc) which is created with help of 'createEmptyMovieclip()' function inside the graph , does not copy.
      If i create same object (Line_mc) on '_root' it will copied.
      my code is .....
      //for create graph
      onClipEvent(load){
      ang = 0
      spd = 2
      _root.Graph_mc.CreateEmptyMovieClip("Line_mc",1)
      with(_root.Graph_mc.Line_mc){
      lineStyle(1,0xffff00,100)
      moveTo(0,0)
      onClipEvent(enterframe){
      l = spd*Math.PI*ang
      yy = 60*(Math.sin(l*ang))
      ang++
      lineTo(xx,yy)
      xx++
        • 1. Re: duplicateMovieClip() problem
          1)  root.Graph_mc.CreateEmptyMovieClip("Line_mc",1)
          should be
          root.Graph_mc.createEmptyMovieClip("Line_mc",1)
          2)  it's not clear what movieclip(s) those clip events are attached to
          3)  you shouldn't use code attached to movieclips
          4)  duplicateMovieClip() has some limitations though i don't see you're hitting one.
          • 2. Re: duplicateMovieClip() problem
            gopal73thakkar Level 1
            should be
            sorry for incomplete code and typing mistake in code in forum in my project "c" should be already small.
            my remain code is...
            //for make a copy of graph
            //click event on movieclip named "copy_mc")
            onClipEvent(load){
            var i = 1
            on(press){
            i++
            duplicateMovieClip(_root.Graph_mc,"copyGraph"+i,i)
            when i click on "copy_mc" it will create duplicate movieclip named "copyGraph2" with whole "Graph_mc" but in this duplicate moviclip "Line_mc" is not copied
            and if i create same "Line_mc" directly on stage with code _root.createEmptyMovieClip("Line_mc",1) and after i click on "copy_mc" with code is duplicateMovieClip(_root.Line_mc,"copyGraph"+i,i), it'll copied
            what is the problem i dont know
            thanks
            • 3. Re: duplicateMovieClip() problem
              that is a limitation of duplicateMovieClip():  it won't duplicate dynamically created children.
              • 4. Re: duplicateMovieClip() problem
                ok then it is possible to that dynamic object attach to any other movieclip ?
                thanks
