1 Reply Latest reply on Nov 3, 2009 6:35 AM by SusieIre
    inline component error
    SusieIre
      I have a main mxml file calling a mxml file to create a drop down LOV. However, when loading the form I get the error #1009
      TypeError: Error #1009: Cannot access a property or method of a null object reference.
      at vidcomponents::QueryLOV/setSelectedItem()[M:\MSU\DevProjectCode\Flex\Workspaces\ucd_epms\ src\vidcomponents\QueryLOV.mxml:122].
      The line in question is this -
      localData = data[
      this.FieldName]; I can't find the problem so help would be very much appreciated , I've pasted some more code below. Thanks.
      --code to call LOV
      <mx:AdvancedDataGridColumn width="120" headerText="Action" dataField="EPST_CODE"
      editable="
      true" sortable="false" rendererIsEditor="true" editorDataField="Value">
      <mx:itemRenderer>
      <mx:Component>
      <comp:QueryLOV DataProvider="{outerDocument.lookup('ACTSTATUSSCH')}" styleName="field" FieldName="EPST_CODE"/>
      </mx:Component>
      </mx:itemRenderer>
      </mx:AdvancedDataGridColumn>
      - LOV File
      <mx:HBox
      xmlns:mx="http://www.adobe.com/2006/mxml" xmlns:comp="vidcomponents.*
      horizontalGap="
      0" verticalGap="0
      verticalScrollPolicy="
      off" horizontalScrollPolicy="off
      dataChange="setSelectedItem(event)"
      creationComplete="initComponent()"
      backgroundColor="
      #E5E4E4"
      <mx:Script>
      <![CDATA[
      import
      mx.utils.StringUtil;
      import
      mx.controls.DataGrid;
      import
      mx.collections.ArrayCollection;
      import
      mx.controls.Alert;
      import
      mx.managers.PopUpManager;
      import
      mx.utils.ObjectUtil;
      Bindable] public var
      DataProvider:ArrayCollection;
      ac:ArrayCollection;
      Bindable] public var autoPopup:Boolean=true
      Bindable] public var showAllItems:Boolean=false
      Bindable] public var allItemsLabel:String = "-- All --"
      public var
      excludeCodes:String;
      public var
      excludeArray:Array;
      public var
      FieldName:String;
      public var UniqueIndicator:Boolean = false
      public var
      DG:DataGrid;
      public var showDescription:Boolean = true
      private var
      _val:String;
      private var
      _desc:String;
      private function initComponent():
      void
      descfield.width =
      this.width - this
      .lovbutton.width;
      descfield.height =
      this
      .height;
      if(ac==null
      ac = ObjectUtil.copy(DataProvider)
      as
      ArrayCollection;
      if(showAllItems==true
      ac.addItemAt({DATA:
      , LABEL:allItemsLabel}, 0);
      _val =
      if ((excludeArray!=null) && (excludeCodes==null
      for (var
      i:Number=0; i<excludeArray.length; i++)
      excludeCodes +=
      ',' + excludeArray[i] + ','
      sync();
      public function set Value(val:String):void
      _val = val;
      sync();
      public function get
      Value():String
      return
      _val;
      public function set Description(desc:String):
      void
      _desc = desc;
      public function get
      Description():String
      return
      _desc;
      private function
      findDescription(dataval:String):String
      if (ac == null
      return null
      for (var
      i:Number=0; i<ac.length; i++)
      if
      (ac[i].DATA == dataval)
      return
      ac[i].LABEL;
      return
      dataval;
      private function sync():
      void
      _desc = findDescription(_val);
      this
      .valuefield.text = _val;
      if(this.showDescription==true
      this
      .descfield.text = _desc;
      else
      this
      .descfield.text = _val;
      private function setSelectedItem(event:Event):
      void
      var
      localData:String;
      if (this.FieldName == null
      if (data != null
      localData = data.toString();
      else
      localData = data[
      this
      .FieldName].toString();
      _val = localData;
      sync();
      public function SetContents(code:String, desc:String):
      void
      _val = code;
      _desc = desc;
      data = code;
      else
      data[
      this
      .FieldName] = code;
      sync();
      private function clickField():
      void
      if (autoPopup==true
      showPopup();
      private function showPopup():
      void
      var dialog:QueryPopup = QueryPopup(PopUpManager.createPopUp(this, QueryPopup, true
      dialog.callingControl =
      this
      dialog.DataProvider =
      this
      .ac;
      PopUpManager.centerPopUp(dialog);
      if
      ((dialog.x + dialog.width)> parentApplication.width)
      dialog.x = parentApplication.width - dialog.width;
      if
      ((dialog.y)<0)
      dialog.y = 0;
      </mx:Script>
      <mx:TextInput id="descfield" editable="false" click="clickField()"
      <mx:Button id="lovbutton" enabled="{this.enabled}" visible="{this.enabled}" click="showPopup()" icon="@Embed(source='../assets/images/up.png')" width="{this.enabled?25:0}"
      <mx:TextInput id="valuefield" change="Value = this.valuefield.text" x="0" y="0" width="1" focusRect="null" visible="false"
        • 1. Re: inline component error
          SusieIre Level 1
          Sorry my message may be a bit too long , the main code that's giving me the error is the function
          void
          var
          localData:String;
          if (data != null
          else
          localData = data[t
          his.FieldName].toString();
          _val = localData;
          sync();
          I would really appreciate some help on this as am a beginner and quite stuck.
          thanks a mil
