0 Replies Latest reply on Nov 3, 2009 6:19 AM by ManojBavikati
    PDF is not Merging. Please help me
    ManojBavikati
      Hi  I have a windows applicatoin which is developed using vb.net and i am trying to Attach or Combine 2 pdf's into one . It works for once or twice and after that it will not attach any pdf . The first pdf stays as such.
      The vb.net code is below. Please help me what was causing the problem and any possible solution.
      Code:
      Dim
      sFileName As String = ""
      sFileName =
      "doc1.pdf"
      FileCopy(sFileName,
      "Temp.pdf")
      Me.wbReport.Navigate("Temp.pdf")
      'Get File Name
      Dim sFileAttach As String = ""
      With Me.OpenFileDialog1
      .DefaultExt =
      "PDF"
      .Multiselect =
      False
      .Title =
      "Select file to attach"
      .FileName =
      .Filter =
      "Adobe PDF Files (*.pdf)|*.pdf"
      .ShowDialog()
      sFileAttach = .FileName
      End With
      If sFileAttach = "" Then
      Exit Sub
      End If
      Dim AcroApp As Object = CreateObject("AcroExch.App")
      ' ACRODISTXLib.PdfDistiller6
      Dim InsertPDDoc As Object = CreateObject("AcroExch.PDDoc")
      Dim RptPDDoc As Object = CreateObject("AcroExch.PDDoc")
      Try
      RptPDDoc.InsertPages(
      CType(RptPDDoc.GetNumPages, Integer) - 1, InsertPDDoc, 0, CType(InsertPDDoc.GetNumPages, Integer), False)
      Catch ex As
      Exception
      MsgBox(
      "Error Attaching Documents. Documents were not attached.")
      End Try
      Nothing
      InsertPDDoc =
      Nothing
      Me.wbReport.Navigate(sFileName)
      Any Suggestions ????
      Thanks in Advance for the help.
      RptPDDoc.Save(1, sFileName)
      RptPDDoc.Close()
      AcroApp.Exit()
      RptPDDoc =
      InsertPDDoc.Close()
      AcroApp.Hide()
      RptPDDoc.Open(sFileName)
      InsertPDDoc.Open(sFileAttach)
