I'm using RoboHelp 8 publishing to WebHelp on XP.
The help system I'm building uses a pop-up window to access the RoboHelp project. When I open the pop-up window in Firefox or Safari, the window size is adjustable by dragging the corners out.
When I open the help system in either Internet Explorer 7 or 8, I am unable to adjust the window size.
Does anyone know if this is something I can fix in RoboHelp?
Thanks for all of your help!
Hi there
Sorry, but your post is a bit on the confusing side. Here's why.
You say that in Firefox or Safari you are able to adjust the size of the window. You say in IE you aren't able to do that. Then you ask if it can be fixed in RoboHelp.
What is confusing is determining whether you WANT the window to be resizable in all browsers or you don't.
Personally, I believe it's all determined by the JavaScript code being used to open the window to begin with. Most likely it's something your developers are doing. Certainly there are some WebHelp window options you may view (Click View > Pods > Project Set up) but the options you define there ONLY apply if you are using the WebHelp API to open your topics. It sounds to me as though your developers simply coded the window to open from there end, but I could be wrong.
Cheers... Rick
Helpful and Handy Links RoboHelp Wish Form/Bug Reporting Form Begin learning RoboHelp HTML 7 or 8 within the day - $24.95! |
Thanks for your help.
Yes, I would like the window size to be adjustable.
And I agree, it seems as if this is something controlled by the developers. I'll look through the view options.
If anyone has any other suggestions, I'm all ears!
We handled this issue outside of RoboHelp.
If anyone else is interested:
This should be completed by the developer who is building the RoboHelp links.
The "resizable=1" parameter allows resizing the window. Once resizing is allowed in Internet Explorer, the Status Bar is added by default. The "status=0" parameter removes the Status Bar. The Status Bar parameter might not work because of security issues.
