2 Replies Latest reply on Nov 3, 2009 6:53 AM by serj_is
    UIComponent.addChild makes items to be visible outside of area
    serj_is Level 1
      Hello,
      I am new with flex and actionscript, so...
      I want to add some sprites inside of container (UIComponent) and this container to act like a "clip area" - limit painting only to items inside of bounds. I want to use this code for custom horizonal scrollingcontainer.PNG
      thanks
      This is code:
      package
      import flash.display.Sprite;
      import mx.core.*;
      import util.*;
           public class HorizontalImageContainer extends UIComponent{
                public var bgColor:int = 0xFFCCFF;
                private var itemWidth:int = 62;
                private var itemHeight: int = 62;
                private var innerSpace:int = 8;
                private var bgColors:Array = [0xFF0000,0x00FF00,0x0000FF];
                private var items:Array = new Array();
                public function HorizontalImageContainer(width:Number=500,height:Number=80,bgColor:int=0xFFCCFF){
                     super();
                     this.bgColor = bgColor;
                     this.width = width;
                     this.height = height;
                     this.graphics.clear();
                     createItemsForTesting();
                     this.graphics.lineStyle(1, 0x000000, 0.5, true);
                     this.graphics.drawRoundRect(0, 0, width-1, height-1, 7, 7);
                private function createItemsForTesting():void{
                     for(var i:int=0;i<20;i++){
                          var x: int = i*(itemWidth+innerSpace);
                          var y: int = 0;
                          var bgColor:int = bgColors[i%3];
                          var text:String = (i+1)+"";
                          var item:Sprite = new Sprite();
                          item.x = x;
                          item.y = y;
                          item.graphics.lineStyle(1,0xFFCCFF, 0.5,
      true);
                          item.graphics.beginFill(0xFFCCFF, 1);
                          item.graphics.drawRoundRect(0, 0, itemWidth-1, itemHeight-1, 7, 7);
                          items.push(item);
                          //if(i>itemsInRow-1){
                          // item.visible = false;
                          this.addChild(item);
