1 Reply Latest reply on Jul 16, 2008 6:34 AM by wkolcz
    Flex 3 and ColdFusion
    wkolcz Level 1
      Not sure if I posted too much the first time, so lets take this one stap.
      I am so confused on this flex2gateway directory and cannot find a single answer in Google or the groups.
      Is the flex2gateway directory something that needs to be added to each app to access CF? I am getting this error on my app (Flex3 and BlueDragon 7):
      faultCode:Client.Error.MessageSend
      faultString:'Send failed'
      faultDetail:'Channel.Connect.Failed error
      NetConnection.Call.Failed: HTTP: Status 403: url: ' http://med.umich.edu/flex2gateway/''
      If I need to add this directory (flex2gateway), what goes in it? I just want to connect to my CFC and populate the Flex app with my data!
        • 1. Re: Flex 3 and ColdFusion
          wkolcz Level 1
          Ok, here is the answer since no one seems to know it. You cannot connect to CF if you A.) are running blue dragon or B.) Dont have the config files set up in Adobe CF.....
          If A or B, you need to use WebService or HTTPRequest...
