7 Replies Latest reply on Nov 3, 2009 12:58 PM by BhargavaSrinarasi
    How to pass arguments to PHP from Flex?
    BhargavaSrinarasi
      I'm new to Flex and I want to pass some arguments to a PHP script that is running on a server.
      I've to send the user name, password and a file to it. I tested the PHP script with a simple HTML form and it works fine.
      How to do the same thing using Flex?
      Sending user name and password is fine. But the file? I'm stuck on that part.
      Any help is appreciated.
        • 1. Re: How to pass arguments to PHP from Flex?
          Louder6Pounder
          You can use the URLrequest and URLVariables i believe.  Here is an example:
          var serverURL:String = serverURL;
          //Create new instance of URLrequest
          var request:URLRequest = new URLRequest(serverURL);
          request.method = URLRequestMethod.POST;
          //Add variables
          var variables:URLVariables = new URLVariables();
          if(!overwrite){
               variables.overwrite = "true";
          }else{
               variables.overwrite = "false";
          variables.fileType =  "jpeg";
          variables.imageByteArray = encodedByteArray;
          request.data = variables;
          //use loader on URLrequest
          var loader:URLLoader = new URLLoader();
          loader.load(request);
          loader.addEventListener(Event.COMPLETE, saveSuccessful);
          • 2. Re: How to pass arguments to PHP from Flex?
            BhargavaSrinarasi Level 1
            Hi, Thanks for the reply.
            But how to assign the file to 'variables'? I mean what should I assign? A file reference? or the path? I'm pasting my PHP code here to help you understand it better. I'm pretty confused. Hope you can help me.
                  <?php
                  $username = $_POST["userName"];
                  $password = $_POST["Password"];
                  $image = $_POST["image"];
                  $filename = $_FILES["image"]['name'];
                  $tmpfilename = $_FILES["image"]['tmp_name'];
                  $fileparts = explode(".", $filename);
                  $ext = $fileparts[count($fileparts) - 1];
                  $newfilename = substr($tmpfilename, 0, strlen($tmpfilename) - strlen($ext))  . $ext;
                  copy($tmpfilename, $newfilename);
                  // The twitter API address
                  $url = 'http://twitter.com/account/update_profile_background_image.xml';
                  $curl_handle = curl_init();
                  curl_setopt($curl_handle, CURLOPT_URL, "$url");
                  curl_setopt($curl_handle, CURLOPT_POST, 1);
                  curl_setopt($curl_handle, CURLOPT_HTTPHEADER, array('Expect:'));
                  curl_setopt($curl_handle, CURLOPT_RETURNTRANSFER, 1);
                  curl_setopt($curl_handle, CURLOPT_CONNECTTIMEOUT, 2);
                  curl_setopt($curl_handle, CURLOPT_POSTFIELDS, array("image" => "@$newfilename"));
                  curl_setopt($curl_handle, CURLOPT_USERPWD, "$username:$password");
                  $buffer = curl_exec($curl_handle);
                  curl_close($curl_handle);
                         echo $buffer;
            Thanks again
            • 3. Re: How to pass arguments to PHP from Flex?
              camfieldaj Level 1
              You should use HTTPService.
                  <mx:HTTPService
                      id="myHTTPService"
                      url="http://someserver/somePHPpage.php"
                      resultFormat="e4x"
                      result="myResultHandler(event);"
                      fault="myFaultHandler(event);"
                   <mx:request xmlns="">
                    <valuePassed>{"somevalue"}</valuePassed>
                   </mx:request>
              in the php page:
              if(isset($_REQUEST["valuePassed"]))
              $localValue = $_REQUEST["valuePassed"];
              //$localValue will contain string literal somevalue.
              • 4. Re: How to pass arguments to PHP from Flex?
                Mayank (Adobe) Adobe Employee
                Have you considered using RemoteObject to access PHP functions from your Flex application? Flash Builder 4 Beta 2 has data centric wizards which help you connect your PHP code to your Flex application.
                This link has some tutorials and videos which can help you get started with PHP & Flex.
                http://sujitreddyg.wordpress.com/flash-builder-4/
                Mayank Kumar
                Computer Scientist, Flash Builder
                • 5. Re: How to pass arguments to PHP from Flex?
                  Hi camfieldaj,
                  My question is what will be the 'somevalue' when I want to send a file? What should I use?
                  • 6. Re: How to pass arguments to PHP from Flex?
                    camfieldaj Level 1
                    Gotcha. Ok, to upload a file to a php script I use the FileReference class.
                    public var fileref:FileReference = new FileReference();
                    in the function that's called when you allow them to upload
                    var rptTypes:FileFilter = new FileFilter("ZIP Files", "*.zip");
                    var allowed:Array = new Array(rptTypes);
                    fileref.browse(allowed);
                    You have to declare a urlRequest to point at your php file.
                    fileref.upload(urlRequest);
                    On the php side:
                    if(isset($_FILES['Filedata']['name']))
                    $real_filename=$_FILES['Filedata']['name'];
                    There's a little more to it, but there are some good examples in the
                    help files and the php method of dealing with uploads is well
                    documented.
                    Hope this helps.
                    • 7. Re: How to pass arguments to PHP from Flex?
                      I got it working with something similar to what you said. Thanks very much!!
                      But it's not working when I run it on standalone swf. Do you know any workaround?
                      Thanks again!
