4 Replies Latest reply on Feb 20, 2011 4:19 AM by Ned Murphy
    Stop Looping Codes
    jess-scene
      When creating a moving flash banner, it will continuously loop.
      Is it respectful for the viewer to only loop it a certian amount of times or does that even matter?
      If so, where could I find the code to accomplish that AND stop it at a certain frame?
      THANK!!
        • 1. Re: Stop Looping Codes
          It's anybody's call how many times something should loop.  It's sometimes something that is better decided after allowing it to loop continuously for awhile to get feedback/reaction.
          To accomplish it, you basically need to keep a count of the number of loops and then use a conditional code to tell the timeline to stop();  This would normally be something like the following that you would place in the frame where you want it to stop.... numLoops and someLimit are homegrown variables...
          if(numLoops == someLimit){
               stop();
          } else {
               numLoops += 1;
          • 2. Re: Stop Looping Codes
            dementedsugar
            I declared
            var numLoops = 0;
            var sumLimit = 2;
            in the first frame,
            then put
            if(numLoops == sumLimit){
                 stop();
            } else {
                 numLoops += 1;
            on the frame I wanted it to stop. But it continues to loop over and over. What am I doing wrong?
            • 3. Re: Stop Looping Codes
              somascope Level 3
              Your issue is that every time you restart your loop, you are re-initializing your variables. In other words, when the loop goes back to, say, frame 1, "var numLoops = 0" is always resetting things to 0.
              A simple fix is to loop to a frame AFTER wherever your vars are being set (like, gotoAndPlay(2), as a simple example). That way, the playhead never passes over them a 2nd time, and avoids them getting reset.
              • 4. Re: Stop Looping Codes
                Don't assign a value in the first frame, just declare it.  The default value will be a zero, but upon returning it will not reset...
                var numLoops:int;
                var sumLimit = 2;
