2 Replies Latest reply on Nov 4, 2009 6:10 AM by psperkins
    IModuleInfo's factory create method returning null
    psperkins
      I have IModuleInfo objects stored for dynamic loading/unloading of Modules in my application. These IModuleInfo's are retrieved , and have their factory's (IFlexModuleFactory) create method called to create an instance of the module. This works fine most of the time. However, on rapid switching between modules (unloading and loading new instances multiple times, quickly) this fails.
      In code:
      info:IModuleInfo =     ...  // retrieve IModuleInfo from some data structure
      // test that it info is not null
      var instance:Object = info.factory.create();
      if ( instance is a module) {
           // This almost always is the case
      else{
           // instance is null here.
           // This happens on occasion when rapidly unloading/loading modules
      Has anyone ever seen this behavior, or have any ideas on what might cause create to return null?
