0 Replies Latest reply on Nov 4, 2009 5:38 AM by Darrell Loverin
    [svn:fx-trunk] 11423: Style manager fixes
    Darrell Loverin Level 4
      Revision: 11423
      Author:   dloverin@adobe.com
      Date:     2009-11-04 05:37:42 -0800 (Wed, 04 Nov 2009)
      Log Message:
      Style manager fixes
      StyleManagerImpl:
      The code to remove style declarations from Subject was calling delete to remove the declaration. It removed the declaration but left an undefined entry in the Array because the array length was not changed. Later when the parent and child arrays are concatenated an undefined entry exists which causes the exception. Using splice() keeps the array length correct. Additionally, when there is only one entry in the array the entire Object from _subject is removed.
      Alert.show() is called from a module and crashes because it is trying to use styles in the top-level app but the top-level app does not use Alert so the styles are not loaded. A work around would be to declare Alert in the top level application to draw in the needed styles. I made a fix in Alert so that work around is not needed.
      Panel:
      Null pointer check for titleBarBackground. This fix avoids the RTE but the Alert has no background.
      Alert:
      Add a module factory argument to Alert.show(). This is an alternative workaround to declaring Alert in the top-level application.
      QE notes: None.
      Doc notes: None.
      Bugs: SDK-23977, SDK-23974, SDK-23995
      Reviewer: Alex
      Tests run: checkintests, components/Alert, Managers/StyleManager, Managers/PopUpManager
      Is noteworthy for integration: No.
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-23977
          http://bugs.adobe.com/jira/browse/SDK-23974
          http://bugs.adobe.com/jira/browse/SDK-23995
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/framework/src/mx/containers/Panel.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/Alert.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/styles/StyleManagerImpl.as
