• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Pb visualisation
New Here ,
Nov 04, 2009 Nov 04, 2009
Hi, i m french so sorry for vocabulary and gramm.
When I export to SWF, text and buttons are blurring. I tried many settings but nothing works...Even the buttons are integrated to captivate blur level of writing.Images that I met are also very vague when I indicate that 100% quality jpeg.it's the same thing for videos that I took in 1024.
I've made an example of parameters that I mentioned and an example image. If I ask you to help me is it was reported that the disturbing blur. My audience is a senior public. Thx for your help.
TOPICS
Import export
Views
661
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND ,
Hi there
How are you viewing your output? Normally what happens when folks report that the quality is suffering, they are simply running the .SWF and they aren't using the available .HTM file Captivate typically creates. So if this is how you are operating, try using the .HTM file Captivate creates and you should see an improved result.
Cheers... Rick
Helpful and Handy Links
Captivate Wish Form/Bug Reporting Form
Adobe Certified Captivate Training
SorcerStone Blog
Captivate eBooks
Votes
Translate
Translate
Report
Report
New Here ,
I use the htm version of Captivate.
thx
Votes
Translate
Translate
Report
Report
LEGEND ,
Hi again
In that first image you listed, where you show the preferences, have you tried clearing that first check box? I think for you it is labeled "Lisser les légendes transparentes"
Cheers... Rick
SorcerStone Blog
Captivate eBooks
Votes
Translate
Translate
Report
Report
New Here ,
Thank you for this information but I have tried this option and other options in that style. I tried to change the quality of the slide. I noticed that if I put two different formatting in the same info , still more trouble.
Votes
Translate
Translate
Report
Report
Community Expert ,
LATEST
Essayez de déactiver les options de compression (du projet et du SWF), la taille du fichier sera plus grand, mais peut-être vous aurez une meilleure qualité. Par contre activez 'Conservez la qualité du dia' (aparemment vous l'avez déactivé, selon votre image). J'utilise la version anglaise de CP, donc je ne suis pas sûre que mes traductions sont correctes, mes excuses.
Try to deactivate the options for compression which will increase the files size, but you could get a better quality. And please keep the option "Retain slide quality setting' activated.
Lilybiri
Votes
Translate
Translate
Report
Report
Resources
Help resources
