0 Replies Latest reply on Nov 4, 2009 10:27 AM by Darrell Loverin
    [svn:fx-trunk] 11436: Unload style fix.
    Darrell Loverin Level 4
      Revision: 11436
      Author:   dloverin@adobe.com
      Date:     2009-11-04 10:27:10 -0800 (Wed, 04 Nov 2009)
      Log Message:
      Unload style fix.
      projects/framework/src/mx/managers/IPopUpManager.as
      projects/framework/src/mx/managers/PopUpManager.as
      projects/framework/src/mx/managers/PopUpManagerImpl.as
          Add moduleFactory parameter to PopUpManager.addPopUp() so the moduleFactory can be controlled separately from the parent.
      projects/framework/src/mx/styles/CSSStyleDeclaration.as
          Test if overrides[styleProp] is undefined instead of non-zero.
      QE notes: None.
      Doc notes: None.
      Bugs: SDK-23030
      Reviewer: Alex
      Tests run: checkintests, Managers/StyleManager, Managers/PopUpManager
      Is noteworthy for integration: No.
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-23030
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/IPopUpManager.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/PopUpManager.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/PopUpManagerImpl.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/styles/CSSStyleDeclaration.as
