2 Replies Latest reply on Nov 5, 2009 8:22 AM by moccamaximum
    Flash Slideshow - playpausebutton
    blossom980
      I have created a slideshow based on the template for slideshow provided by Flash and some other blogs posts i have found.
      I have a layer with a picture on consecutive frames.
      I have another later that has just my text to display always.
      I have created another layer called Buttons and in the first keyframe i typed stop();  And added buttons by draging and dropping <back button
      and > foward button. I used script:
      for the back button
      on (release) {
      if (this._currentframe == 1) {
      gotoAndStop (this._totalframes);
      } else {
      prevFrame ();
      and for the foward
      on (release) {
      if (this._currentframe == this._totalframes) {
      gotoAndStop (1);
      } else {
      nextFrame ();
      I have gotten them to work if you hit the button, it changes to the next picture.
      I want the pictures to continously play and i want to add a Pause/Play button .
      If you hit the pause it will stop and then you can resume the slideshow by hitting the button again which will be a Play button.
      I cannot #1 get the show to just move on its own (i guess i have to add additional frames to each photo?)
      I have been searching for a Pause Play button ALLLLL day. Please help.
        • 1. Re: Flash Slideshow - playpausebutton
          lemieuxster
          I do not know of a good drag-and-drop play/pause button but you could make a Play/Pause button that controlled an interval (http://www.adobe.com/support/flash/action_scripts/actionscript_dictionary/actionscript_dic tionary646.html) that would advance the frame every given number of seconds. The play/pause button would then either create or stop that interval. You would keep track of the currently playing status with a variable (like var currentlyPlaying;)
          • 2. Re: Flash Slideshow - playpausebutton
            moccamaximum Level 5
            1.From what I understand you got the scope of the buttons wrong.
            I suppose you want to do this:
            for the back button
            on (release) {
            //in this case "this._parent" adresses the main timeline
            if (this_parent._currentframe == 1) {
            this_parent.gotoAndStop (this_parent._totalframes);
            } else {
            this_parent.prevFrame ();
            //same thing for the fwd button
            2.If you find the setInterval function to much effort you can always "cheat" a timer with enterFrame
            var timer = 0;
            var playing:Boolean = true;
            //the framerate of your movie
            var framespersecond= 30;
            _root.onEnterFrame{
              if(playing){
               timer++;
               if(timer%(5*framespersecond)){
                 dosomethingevery5seconds();
                 //reset timer to reduce counting time
                 timer=0;
            function dosomethingevery5seconds():void{
              //go to the next picture after 5 seconds;
            _root.nextFrame();
            pause_btn.onRelease = function(){
              playing = false;
            play_btn.onRelease = function(){
              playing = true;
