31 Replies Latest reply on Nov 10, 2009 7:21 PM by Tim Flippance
    Downscaling
    Tim Flippance Level 1
      I want to downscale HDV 16:9 to PAL DVD at maximum render quality. Do I do this by (in Encore) selecting PAL DV High Quality in the Export
      settings?
        • 1. Re: Downscaling
          Jeff Bellune Adobe Community Professional
          Have a look at my tutorial:
          CS4 HD to SD
          -Jeff
          • 2. Re: Downscaling
            Thanks Jeff that's very helpful.
            Just a couple of points I'm not sure about:
            in the Preset drop-down list should I choose PAL Widescreen High Quality,
            and what should I set M frames and N frames to for 25i PAL?
            thanks Tim
            • 3. Re: Downscaling
              I'm an NTSC guy, but I took a look at the PAL Widescreen High Quality preset and it looks like the correct choice.  I also think that the default GOP settings for that preset should work OK.
              Encode a short section of your timeline and burn that to an RW disc and then test it on a hardware DVD player.  Then you'll know for sure if you got everything right.
              -Jeff
              • 4. Re: Downscaling
                Thanks. What sort of faults would I expect to see if it isn't right? Flickering? Bad definition? Jerky movement?
                • 5. Re: Downscaling
                  Yes to any or all of the above.
                  The only caveat to jerky motion would be if you used 30p or 24p
                  footage.  Fast motion across the frame won't look with either of those,
                  no matter how good the scaling is.
                  -Jeff
                  • 6. Re: Downscaling
                    Thanks a lot Jeff
                    • 7. Re: Downscaling
                      Jeff
                      I've had another thought.  Most of this movie was filmed in 25p packaged as i, which presumably means 50 fields per second, but with the upper and lower field photographed at the same instant in time, effectively giving 25p. My question is does this mean I have to use a different downscaling process?  I can't see why it should, but you're the expert. You'll probably say do tests, but I can't get a rewritable disc to work, and in any case I need to know that the method I'm using is theoreticaly the best method, and I'm getting the best possible quality.
                      Thanks a lot    Tim
                      • 8. Re: Downscaling
                        That's not good, and you should fix it.
                        My tests on 30p AVCHD footage that was packaged as 60i came out OK using the 30p scaling method that I outlined in the tutorial.  I expect that 25p over 50i will do OK if it's treated as 25p.
                        -Jeff
                        • 9. Re: Downscaling
                          Jeff (or anyone)
                          when I've done the downscaling in the Export Settings window, I don't know how to burn what I've done to disc. I can't find any file anywhere.
                          • 10. Re: Downscaling
                            Did you run the queue in the Adobe Media Encoder?
                            -Jeff
                            • 11. Re: Downscaling
                              No I didn't. When it had finished converting the Export Settings window just stayed there and didn't ask me to Save or anything, so I didn't know what to do.
                              Here's another (less important) question: is it best to always set Maximum Bit Rate to the highest possible setting assuming that the project will fit onto the disc?
                              Tim
                              • 12. Re: Downscaling
                                Harm Millaard Level 7
                                Only use Maximum Render Quality for your Master. It will take around 4 times as long to render, so you only want to use that for the master.
                                • 13. Re: Downscaling
                                  Time for "back to basics".
                                  What version of Premiere Pro are you using?
                                  Are you encoding from Pr or En?  My tutorial centers on Pr, so I assumed that's where you set up and executed the transcoding of your video.
                                  If you transcode outside of En, then you must do your own bit budgeting.
                                  -Jeff
                                  • 14. Re: Downscaling
                                    Yes I'm using Maximum Render Quality, but I'm also interested in whether it's best to use the highest possible Maximum Bit Rate (and how do you calculate the required bit rate?)
                                    • 15. Re: Downscaling
                                      Jeff
                                      I was using 4.1.0 but I decided to re instal 4.0 because since updating to 4.1.0 several problems appeared: 1/ when trying to burn in Encore it always aborts just before the burn starts, 2/ when I open a project it says "Rendering Required Files" and does so before it will run, 3/ previously rendered clips are now unrendered and have to be re rendered.
                                      So I reinstalled 4.0 and the above problems disappeared.
                                      So I'm using 4.0
                                      I did it all as you said in your tutorial.
                                      I was in Pr, clicked File > Export > Media to bring up the Export Settings window, etc.
                                      • 17. Re: Downscaling
                                        Go into Pr, go to File | Export | Media and when the AME UI opens up, look at where the AME wants to save the file.  That's likely where you'll find your exported file.
                                        -Jeff
                                        • 18. Re: Downscaling
                                          You should uninstall Pr, En and the whole Production Premium suite (if you have it).  Then run the CS4 Clean Script at least twice, rebooting between each run.  Then install 4.0 and the 4.1 update and try again.
                                          -Jeff
                                          • 19. Re: Downscaling
                                            Thanks Harm
                                            • 21. Re: Downscaling
                                              It seems to be in 4.0 but I don't know what it's called so I'll have to do it again. But now when I click on the dropdown menu to select Use Maximum Render Quality it is not there, it only lists Use Preview Files, Include Source XMP Meta Data, File Info...
                                              sorry this is all very basic stuff but I've never done this before
                                              • 22. Re: Downscaling
                                                It's possible that MRQ was added in the 4.1 update.
                                                -Jeff
                                                • 23. Re: Downscaling
                                                  I havn't done the 4.1 update yet. In that little dropdown window it used to have Use Maximum Render Quality listed, now its not there!
                                                  Or are you saying Use Maximum Render Quality is not available in 4.0?
                                                  Yes that's obviously what you're saying
                                                  • 24. Re: Downscaling
                                                    Curt Wrigley Level 4
                                                    Im going to vomit if people are going to start begging for points.
                                                    • 25. Re: Downscaling
                                                      Jim_Simon Level 8
                                                      http://smileys.on-my-web.com/repository/Disgusting/vomit-5.gif
                                                      Curt.....Harm
                                                      • 26. Re: Downscaling
                                                        I did what you suggested and it has cured the rendering faults and MRQ has reappeared in Export Settings.
                                                        I downscaled my project to DVD using MRQ and it worked OK. The only problem is it puts the picture and the sound in two separate files and when I burn the DVD (using ImgBurn) it has no sound!
                                                        And here's a strange thing: this video is only 3.5 minutes long but it has filled up about 1/3 of the DVD! (about 1/2 inch of width on the disc).
                                                        The picture quality is good but has a slight "wobbly" effect on horiz edges on pan up shots. I did it in 25i so I might try 25p and see if it is better.
                                                        Two more questions:  would MRQ produce better quality on Blu-ray discs too?
                                                        For this video I used several clips from the same source footage as a previous video (with different in/out points) and this has messed up the previous video, its clips now start and stop at the wrong point. Is this normal?
                                                        • 27. Re: Downscaling
                                                          RDA972 Level 3
                                                          Jim, this will probably get "The Post of the Year Award".
                                                          It had me in stiches.
                                                          • 28. Re: Downscaling
                                                            Hooray!
                                                            In the export settings dialog, go to the multiplexer tab.  Set multiplexing to DVD.
                                                            If you burned to DVD-R or DVD-RW, then at least 1 GB of info must be written to disc.  If the disc content isn't that big, then the disc is padded by writing fake data until the file size is 1 GB.
                                                            Not unless scaling and/or deinterlacing were involved.
                                                            In Pr or En?  Dynamic Link or overwriting existing files when you export?
                                                            -Jeff
                                                            • 29. Re: Downscaling
                                                              Jeff   thanks for all that very useful info.
                                                              In Pro.  I made this new video in the same timeline as the previous project, using some clips from the same source footage, but with different in/out points, and now it has upset the old project. When I run the old project in Pro, those clips are all messed up.
                                                              • 30. Re: Downscaling
        Premiere is a non-destructive editor.  Changing in/out points in a sequence has no effect on the actual source media that is stored on your hard drive.  All that changes is the reference to frames in the source clip.  All the original frames are there, it's just that Pr is now looking only at the frames defined by the new in/out points.
        The only way to mess up clips that exist on your hard drive is to export new clips with the same file names as the old clips, thereby overwriting the old clips.  Is that what you did?
        -Jeff
        • 31. Re: Downscaling
        No but I think this may have happened after I uninstalled Pro then reinstalled then updated, because Pro had a lot of trouble finding the source footage after the update (I've got two HDs with different stuff on each, and some of the stuff is duplicated on both HDs)
        A different subject:  is the "wobbly"or "blinking" effect on horizontal lines during upward pans caused by the wrong value for N frames? I used 12 which was the default value
