0 Replies Latest reply on Nov 4, 2009 3:10 PM by Carol L. Frampton
    [svn:fx-trunk] 11445: TLF build 544.
    Carol L. Frampton Level 2
      Revision: 11445
      Author:   cframpto@adobe.com
      Date:     2009-11-04 15:10:46 -0800 (Wed, 04 Nov 2009)
      Log Message:
      TLF build 544.  textLayout.zip was restructured to match our preferred directory structure so move files around again to match.  Their build file builds in place in our directory structure straight out of the zip.  It looks like our version of the file, not the one they used to include.
      Fixes since the last update:
      Build 544
      • Fix 2472372 Adornments are lost when lines scroll out of view.
      • Fix underline offset for small point sizes.
      QE notes:
      Doc notes:
      Bugs:
      Reviewer: Gordon and Steve know I am doing this
      Tests run: checkintests
      Is noteworthy for integration: no
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/textLayout/ReleaseNotes.txt
          flex/sdk/trunk/frameworks/projects/textLayout/build.xml
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/BuildInfo.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/elements/FlowGroupEle ment.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/elements/FlowLeafElem ent.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/elements/ParagraphEle ment.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/elements/TextFlow.as
          flex/sdk/trunk/frameworks/projects/textLayout/tlf.properties
      Added Paths:
          flex/sdk/trunk/frameworks/projects/textLayout/manifest.xml
      Removed Paths:
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout/
