0 Replies Latest reply on Nov 4, 2009 4:02 PM by deepa subramaniam (adobe)
    [svn:fx-trunk] 11446: Bugfixes, ASDoc entries and PARB changes for FXG 2.0.
      Revision: 11446
      Author:   dsubrama@adobe.com
      Date:     2009-11-04 16:02:15 -0800 (Wed, 04 Nov 2009)
      Log Message:
      1.) PARB-mandated change. The shader classes have moved from spark.primtives.shaders to spark.primitives.supportClasses.shaders
      2.) Fix for http://bugs.adobe.com/jira/browse/SDK-23949 - If luminosityClip or luminosityInvert changes dynamically on a Group or GraphicElement, we recalculate the luminosity mask shader filter's mode and reapply the filter.
      3.) AsDoc entries for Group.luminosityClip, Group.luminosityInvert, Group.maskType, GraphicElement.luminosityClip, GraphicElement.luminosityInvert, GraphicElement.maskType and MaskType.CLIP (SDK-23843, SDK-23773)
      QE notes: None, regress
      Doc notes: Can you give the ASDoc entries a once-over?
      Bugs: SDK-23949, SDK-23843, SDK-23773
      Reviewer: Evtim
      Tests run: FXG static and runtime
      Is noteworthy for integration: Yes - package changes for the shader classes may affect tools
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-23843
          http://bugs.adobe.com/jira/browse/SDK-23773
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/spark/src/SparkClasses.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/Group.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/supportClasses/GroupBase.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/core/MaskType.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/primitives/supportClasses/GraphicEleme nt.as
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/fxg/FlexFXG2SWFTranscoder.java
      Added Paths:
          flex/sdk/trunk/frameworks/projects/spark/src/spark/primitives/supportClasses/shaders/
          flex/sdk/trunk/frameworks/projects/spark/src/spark/primitives/supportClasses/shaders/Colo r.pbj
          flex/sdk/trunk/frameworks/projects/spark/src/spark/primitives/supportClasses/shaders/Colo rBurn.pbj
          flex/sdk/trunk/frameworks/projects/spark/src/spark/primitives/supportClasses/shaders/Colo rBurnShader.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/primitives/supportClasses/shaders/Colo rDodge.pbj
          flex/sdk/trunk/frameworks/projects/spark/src/spark/primitives/supportClasses/shaders/Colo rDodgeShader.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/primitives/supportClasses/shaders/Colo rShader.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/primitives/supportClasses/shaders/Excl usion.pbj
          flex/sdk/trunk/frameworks/projects/spark/src/spark/primitives/supportClasses/shaders/Excl usionShader.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/primitives/supportClasses/shaders/Hue. pbj
          flex/sdk/trunk/frameworks/projects/spark/src/spark/primitives/supportClasses/shaders/HueS hader.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/primitives/supportClasses/shaders/Lumi nosity.pbj
          flex/sdk/trunk/frameworks/projects/spark/src/spark/primitives/supportClasses/shaders/Lumi nosityMaskFilter.pbj
          flex/sdk/trunk/frameworks/projects/spark/src/spark/primitives/supportClasses/shaders/Lumi nosityMaskShader.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/primitives/supportClasses/shaders/Lumi nosityShader.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/primitives/supportClasses/shaders/Satu ration.pbj
          flex/sdk/trunk/frameworks/projects/spark/src/spark/primitives/supportClasses/shaders/Satu rationShader.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/primitives/supportClasses/shaders/Soft Light.pbj
          flex/sdk/trunk/frameworks/projects/spark/src/spark/primitives/supportClasses/shaders/Soft LightShader.as
      Removed Paths:
          flex/sdk/trunk/frameworks/projects/spark/src/spark/primitives/shaders/
