0 Replies Latest reply on Nov 4, 2009 5:10 PM by rfrishbe
    [svn:fx-trunk] 11449: Adding OSMF to our framework.
    rfrishbe Level 3
      Revision: 11449
      Author:   rfrishbe@adobe.com
      Date:     2009-11-04 17:09:57 -0800 (Wed, 04 Nov 2009)
      Log Message:
      Adding OSMF to our framework.  The osmf.swc builds automatically as part of our build process.  I'm also adding new video classes that use OSMF, spark.components.VideoDisplay and spark.components.VideoPlayer2.  The other VideoElement and VideoPlayer will be replaced by these.  The new video components are not yet complete; this is an initial checkin for these components.
      QE notes: -
      Doc notes: -
      Bugs: -
      Reviewer: Deepa (only the build processes stuff)
      Tests run: checkintests
      Is noteworthy for integration: Yes
      Modified Paths:
          flex/sdk/trunk/build.xml
          flex/sdk/trunk/frameworks/build.xml
          flex/sdk/trunk/frameworks/build_framework.xml
          flex/sdk/trunk/frameworks/flex-config.xml
          flex/sdk/trunk/frameworks/projects/spark/build.xml
          flex/sdk/trunk/frameworks/projects/spark/defaults.css
          flex/sdk/trunk/frameworks/projects/spark/src/SparkClasses.as
          flex/sdk/trunk/frameworks/spark-manifest.xml
      Added Paths:
          flex/sdk/trunk/frameworks/projects/osmf/
          flex/sdk/trunk/frameworks/projects/osmf/build.xml
          flex/sdk/trunk/frameworks/projects/osmf/src/
          flex/sdk/trunk/frameworks/projects/osmf/src/OSMFClasses.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/audio/
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/audio/AudioAudibleTrait.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/audio/AudioElement.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/audio/AudioPausableTrait.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/audio/AudioPlayableTrait.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/audio/AudioSeekableTrait.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/audio/AudioTemporalTrait.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/audio/SoundAdapter.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/audio/SoundDownloadableTrait.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/audio/SoundLoadedContext.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/audio/SoundLoader.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/composition/
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/composition/ChildSeekOperation.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/composition/CompositeAudibleTrait.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/composition/CompositeBufferableTrait .as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/composition/CompositeElement.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/composition/CompositeLoadableTrait.a s
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/composition/CompositeMediaTraitBase. as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/composition/CompositeMediaTraitFacto ry.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/composition/CompositeMetadata.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/composition/CompositePausableTrait.a s
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/composition/CompositePlayableTrait.a s
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/composition/CompositeSeekOperationIn fo.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/composition/CompositeSeekableTrait.a s
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/composition/CompositeSpatialTrait.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/composition/CompositeTemporalTrait.a s
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/composition/CompositeViewableTrait.a s
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/composition/CompositionMode.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/composition/IReusable.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/composition/ParallelElement.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/composition/ParallelSeekOperationInf o.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/composition/ParallelSeekableTrait.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/composition/ParallelSpatialTrait.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/composition/ParallelSwitchableTrait. as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/composition/ParallelViewableTrait.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/composition/SerialElement.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/composition/SerialElementSegment.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/composition/SerialElementTransitionM anager.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/composition/SerialSeekOperationInfo. as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/composition/SerialSeekableTrait.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/composition/SerialSpatialTrait.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/composition/SerialSwitchableTrait.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/composition/SerialViewableTrait.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/composition/TraitAggregator.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/composition/TraitAggregatorEvent.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/composition/TraitLoader.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/composition/TraitLoaderEvent.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/content/
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/content/ContentDownloadableTrait.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/content/ContentElement.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/content/ContentLoadedContext.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/content/ContentLoader.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/display/
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/display/MediaElementSprite.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/display/MediaPlayerSprite.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/display/ScalableSprite.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/display/ScaleMode.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/drm/
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/drm/DRMServices.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/events/
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/events/AuthenticationCompleteEvent.a s
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/events/AuthenticationFailedEvent.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/events/BeaconEvent.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/events/BufferTimeChangeEvent.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/events/BufferingChangeEvent.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/events/BytesDownloadedChangeEvent.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/events/BytesTotalChangeEvent.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/events/DimensionChangeEvent.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/events/DurationChangeEvent.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/events/FacetValueChangeEvent.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/events/FacetValueEvent.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/events/GatewayChangeEvent.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/events/LoadableStateChangeEvent.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/events/LoaderEvent.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/events/MediaError.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/events/MediaErrorCodes.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/events/MediaErrorEvent.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/events/MediaEvent.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/events/MediaPlayerCapabilityChangeEv ent.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/events/MediaPlayerStateChangeEvent.a s
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/events/MetadataEvent.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/events/MutedChangeEvent.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/events/NetConnectionFactoryEvent.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/events/NetNegotiatorEvent.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/events/PanChangeEvent.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/events/PausedChangeEvent.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/events/PlayheadChangeEvent.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/events/PlayingChangeEvent.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/events/PluginLoadEvent.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/events/SeekingChangeEvent.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/events/SwitchingChangeEvent.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/events/TraitEvent.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/events/TraitsChangeEvent.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/events/ViewChangeEvent.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/events/VolumeChangeEvent.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/gateways/
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/gateways/HTMLGateway.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/gateways/HTMLGatewayElementProxy.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/gateways/RegionGateway.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/html/
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/html/HTMLElement.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/html/HTMLLoadableTrait.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/image/
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/image/ImageElement.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/image/ImageLoader.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/layout/
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/layout/AbsoluteLayoutFacet.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/layout/AnchorLayoutFacet.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/layout/DefaultLayoutRenderer.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/layout/ILayoutContext.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/layout/ILayoutRenderer.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/layout/ILayoutTarget.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/layout/LayoutAttributesFacet.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/layout/LayoutContextSprite.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/layout/LayoutRendererBase.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/layout/LayoutRendererFacet.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/layout/LayoutUtils.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/layout/MediaElementLayoutTarget.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/layout/PaddingLayoutFacet.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/layout/RegistrationPoint.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/layout/RelativeLayoutFacet.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/logging/
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/logging/ILogger.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/logging/ILoggerFactory.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/logging/Log.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/logging/TraceLogger.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/logging/TraceLoggerFactory.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/media/
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/media/DefaultMediaResourceHandlerRes olver.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/media/IContainerGateway.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/media/IMediaGateway.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/media/IMediaReferrer.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/media/IMediaResource.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/media/IMediaResourceHandler.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/media/IMediaResourceHandlerResolver. as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/media/IMediaTrait.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/media/IURLResource.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/media/LoadableMediaElement.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/media/MediaElement.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/media/MediaFactory.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/media/MediaInfo.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/media/MediaInfoType.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/media/MediaPlayer.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/media/MediaPlayerState.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/media/URLResource.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/metadata/
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/metadata/IFacet.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/metadata/IIdentifier.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/metadata/KeyValueFacet.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/metadata/MediaType.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/metadata/MediaTypeFacet.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/metadata/Metadata.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/metadata/MetadataNamespaces.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/metadata/MetadataUtils.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/metadata/MetadataWatcher.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/metadata/MimeTypes.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/metadata/ObjectFacet.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/metadata/ObjectIdentifier.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/metadata/StringIdentifier.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/metadata/TemporalFacet.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/metadata/TemporalFacetEvent.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/metadata/TemporalIdentifier.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/net/
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/net/NetClient.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/net/NetConnectionAttempt.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/net/NetConnectionCodes.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/net/NetConnectionFactory.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/net/NetLoadedContext.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/net/NetLoader.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/net/NetNegotiator.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/net/NetStreamAudibleTrait.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/net/NetStreamBufferableTrait.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/net/NetStreamCodes.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/net/NetStreamContentProtectableTrait .as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/net/NetStreamDownloadableTrait.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/net/NetStreamPausableTrait.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/net/NetStreamPlayableTrait.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/net/NetStreamSeekableTrait.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/net/NetStreamTemporalTrait.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/net/dynamicstreaming/
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/net/dynamicstreaming/DroppedFramesRu le.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/net/dynamicstreaming/DynamicNetStrea m.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/net/dynamicstreaming/DynamicStreamin gItem.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/net/dynamicstreaming/DynamicStreamin gNetLoadedContext.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/net/dynamicstreaming/DynamicStreamin gNetLoader.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/net/dynamicstreaming/DynamicStreamin gResource.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/net/dynamicstreaming/INetStreamMetri cs.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/net/dynamicstreaming/ISwitchingRule. as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/net/dynamicstreaming/InsufficientBan dwidthRule.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/net/dynamicstreaming/InsufficientBuf ferRule.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/net/dynamicstreaming/MetricsProvider .as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/net/dynamicstreaming/NetStreamSwitch ableTrait.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/net/dynamicstreaming/SufficientBandw idthRule.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/net/dynamicstreaming/SwitchingDetail .as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/net/dynamicstreaming/SwitchingDetail Codes.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/net/dynamicstreaming/SwitchingRuleBa se.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/plugin/
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/plugin/DynamicPluginLoader.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/plugin/IPluginInfo.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/plugin/PluginClassResource.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/plugin/PluginElement.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/plugin/PluginEntry.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/plugin/PluginLoadedContext.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/plugin/PluginLoader.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/plugin/PluginLoadingState.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/plugin/PluginManager.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/plugin/StaticPluginLoader.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/proxies/
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/proxies/ListenerProxyElement.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/proxies/ProxyElement.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/proxies/TemporalProxyElement.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/swf/
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/swf/SWFElement.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/swf/SWFLoader.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/tracking/
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/tracking/Beacon.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/tracking/BeaconElement.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/tracking/BeaconPlayableTrait.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/traits/
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/traits/AudibleTrait.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/traits/BufferableTrait.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/traits/ContentProtectableTrait.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/traits/DownloadableTrait.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/traits/IAudible.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/traits/IBufferable.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/traits/IContentProtectable.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/traits/IDisposable.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/traits/IDownloadable.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/traits/ILoadable.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/traits/ILoadedContext.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/traits/ILoader.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/traits/IPausable.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/traits/IPlayable.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/traits/ISeekable.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/traits/ISpatial.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/traits/ISwitchable.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/traits/ITemporal.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/traits/IViewable.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/traits/LoadState.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/traits/LoadableTrait.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/traits/LoaderBase.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/traits/MediaTraitBase.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/traits/MediaTraitType.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/traits/PausableTrait.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/traits/PlayableTrait.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/traits/SeekableTrait.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/traits/SpatialTrait.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/traits/SwitchableTrait.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/traits/TemporalTrait.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/traits/ViewableTrait.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/utils/
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/utils/BinarySearch.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/utils/FMSHost.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/utils/FMSURL.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/utils/HTTPLoadedContext.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/utils/HTTPLoader.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/utils/MediaFrameworkStrings.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/utils/URL.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/utils/Version.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/video/
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/video/CuePoint.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/video/CuePointType.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/video/VideoElement.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/VideoDisplay.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/VideoDisplay.png
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/VideoPlayer2.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/mediaClasses/DynamicStreami ngVideoItem.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/mediaClasses/DynamicStreami ngVideoSource.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/VideoPlayerSkin2.mxml
