0 Replies Latest reply on Nov 4, 2009 10:34 PM by DavidArcher2
    Tree cellRenderer not working
    DavidArcher2
      The following test code adds an asterisk in front of the node labels of a Tree component.
      It works in a trivial Flash document but displays blank labels in a much more complex one. In both cases the library contains a Movie Clip with name, linkage identifier and AS 2.0 class all set to "MyTreeCell".
      Can anyone suggest why this code may not work, propose an alternative which may work, or provide a strategy for diagnosis?
      Thanks!
      David.
      Scene:Layer:Frame:
      createClassObject(mx.controls.Tree, "myTree", 1);
      myTree.dataProvider = '<node label="Mail"><node label="In"/><node label="Out"/></node>';
      myTree.cellRenderer = "MyTreeCell";
      MyTreeCell.as:
      class MyTreeCell extends mx.core.UIComponent
        var myCell : TextField;
        var owner;
        var listOwner : MovieClip;
        var getCellIndex : Function;
        var getDataLabel : Function;
        function MyTreeCell()
        function createChildren(Void) : Void
          if (myCell == undefined)
            createLabel("myCell", 1);
            myCell.selectable = false;
        function size(Void) : Void
          myCell.setSize(__width - 2, __height - 2);
        function setValue(str:String, item:Object, sel:Boolean) : Void
          myCell.text = (item == undefined ? "" : "*" + str);
        function getPreferredHeight(Void) : Number
          return myCell.getPreferredHeight();
