2 Replies Latest reply on Nov 5, 2009 2:38 AM by Michel.B
    Change AMF-Polling-Interval in LiveCycle Workspace
    Michel.B
      Hello,
      Is it possible to change the polling-interval for the amfpolling-channel in LiveCycle Workspace?
      Or just disable polling?
      The default polling-interval is about 3 seconds to the url /workspace-server/messagebroker/amfpolling
      Many thanks for any hint.
      Kind regards,
      Michel
        • 1. Re: Change AMF-Polling-Interval in LiveCycle Workspace
          AnkitY
          As far as I know there is a file service-config.xml available at LiveCycle_ES_SDK/misc/Process_Management/Workspace/adobe-workspace-src.
          In this config file once can configure polling interval.
          <channel-definition id="secure-workspace-polling-amf" class="mx.messaging.channels.SecureAMFChannel">
                      <endpoint uri="https://{server.name}:{server.port}/workspace-server/messagebroker/amfsecurepolling"
                          class="flex.messaging.endpoints.SecureAMFEndpoint"/>
                      <properties>
                          <polling-enabled>true</polling-enabled>
                          <polling-interval-seconds>8</polling-interval-seconds>
                          <add-no-cache-headers>false</add-no-cache-headers>
                      </properties>
                  </channel-definition>
                  <channel-definition id="workspace-polling-amf" class="mx.messaging.channels.AMFChannel">
                      <endpoint uri="http://{server.name}:{server.port}/workspace-server/messagebroker/amfpolling"
                          class="flex.messaging.endpoints.AMFEndpoint"/>
                      <properties>
                      </properties>
              </channels>
          Please try modifying this file. Hope this helps.
          • 2. Re: Change AMF-Polling-Interval in LiveCycle Workspace
            Michel.B Level 1
            Thank you for your answer.
            I have modified the services-config.xml in LiveCycle_ES_SDK/misc/Process_Management/Workspace/adobe-workspace-src as you described.
            Unfortunately without success.
            We are using a customized LiveCycle Workspace.
            I have modified the polling-interval value in the following services-config.xml files:
            • The services-config.xml in the root directory of the LiveCycle Worskace SDK source (in FlexBuilder)
            • The services-config.xml on the server in the directory \LiveCycle_ES_SDK\misc\DataServices\Server-Configuration and referred to it in the core settings of the LiveCycle-Administration (adminui)
            And the Workspace (the customized and the original one) is still polling every 3 seconds.
            Is the polling used for the QueueSharing functionality? Is it possible to disable this feature?
            Many thanks!
            Michel
