2 Replies Latest reply on Nov 5, 2009 10:50 PM by ne.ha
    How do i Drag and drop From one tree to another and vise versa?
    ne.ha
      I have two tree structures and i'm trying to drag a leaf of a branch from one tree to another and vise versa. i'm using flex 3 to code it. I'm also trying to put a prevention on dropping a leaf of one tree from being dropped inside a branch of another tree. Anything that is dragged over to another tree should be placed as a dangling node in that tree. Please share this code and help me find a solution.
      <mx:Application
      xmlns:mx="
      http://www.adobe.com/2006/mxml
      xmlns:comp="
      com.adobe.flex.extras.controls.*
      initialize="data2
      new
      ArrayCollection(countries);"
      layout="
      absolute
      verticalAlign="
      middle" backgroundColor="white
      height="
      551"
      <mx:Script>
      <![CDATA[
      import
      mx.events.FlexEvent;
      import
      mx.collections.ArrayCollection;
      import
      mx.controls.Alert;
      import
      mx.events.DragEvent;
      import
      mx.managers.DragManager;
      import
      mx.core.DragSource;
      import
      mx.core.UIComponent;
      import
      mx.controls.Tree;
      // data provider for role name
      Bindable] private var
      data2: ArrayCollection;
      // variable to store the node that is dragged from a tree
      private var draggedItemOfAccessTree:XML = null
      private var draggedItemOfExclusionTree:XML = null
      private var dragItemAccess:DisplayObject =null
      private var dragItemExclusion:DisplayObject =null
      // Array to store the Role list
      Bindable]public var
      countries: Array = [
      {id: 0, name:
      "Role 1"
      {id: 1, name:
      "Role 2"
      {id: 2, name:
      "Role 3"
      {id: 3, name:
      "Role 4"
      {id: 4, name:
      "Role 5"
      {id: 5, name:
      "Role 6"
      {id: 6, name:
      "Role 7"
      {id: 7, name:
      "Role 8"
      {id: 8, name:
      "Role 9"
      {id: 9, name:
      "Role 10"
      {id: 10,name:
      "Role 11"
      // this event is called when we begin dragging a node in a tree
      private function onAccessListDragEnter( event:DragEvent ) : void
      event.preventDefault();
      var
      ds1:DragSource = event.dragSource;
      var items1:Array = ds1.dataForFormat("treeItems") as
      Array;
      if (items1 != null && items1.length > 0 && (items1[0] is
      XML))
      draggedItemOfAccessTree = items1[0];
      dragItemAccess = items1[0]
      as
      DisplayObject;
      DragManager.acceptDragDrop(UIComponent(event.currentTarget));
      private function onExclusionListDragEnter( event:DragEvent ) : void
      var
      ds2:DragSource = event.dragSource;
      var items2:Array = ds2.dataForFormat("treeItems") as
      Array;
      if (items2 != null && items2.length > 0 && (items2[0] is
      XML))
      draggedItemOfExclusionTree = items2[0];
      dragItemExclusion =items2[0]
      as
      DisplayObject;
      private function onAccessListDragOver( event:DragEvent ) : void
      var
      var1:Number = AccessTree.selectedIndex;
      var
      var2:Number = ExclusionTree.calculateDropIndex(event);
      var node1:XML = AccessTree.selectedItem as
      XML;
      var node2:XML = ExclusionTree.calculateDropIndex(event) as
      XML;
      //restrict drag & drop to nodes within same parent
      if
      (draggedItemOfAccessTree.parent() == node1.parent() || draggedItemOfAccessTree.parent() != node1.parent())
      DragManager.showFeedback(DragManager.NONE);
      //return;
      else
      DragManager.showFeedback(DragManager.MOVE);
      private function onExclusionListDragOver( event:DragEvent ) : void
      var
      var1:Number = ExclusionTree.selectedIndex;
      var
      var2:Number = AccessTree.calculateDropIndex(event);
      var node1:XML = AccessTree.calculateDropIndex(event) as
      XML;
      var node2:XML = ExclusionTree.selectedItem as
      XML;
      if
      ( draggedItemOfExclusionTree.parent() == node2.parent() || draggedItemOfExclusionTree.parent() != node2.parent())
      // return;
      else
      private function onAccessListDragDrop( event:DragEvent ) : void
      var
      Sindex:Number = AccessTree.selectedIndex;
      var
      Eindex:Number= ExclusionTree.calculateDropIndex(event);
      var Enode:XML = ExclusionTree.selectedItem as
      XML;
      var Anode:XML = AccessTree.selectedItem as
      XML;
      if
      ((draggedItemOfAccessTree.parent() != Anode.parent()) )
      AccessTree.removeChildAt(Sindex);
      ExclusionTree.addChildAt(dragItemAccess , Eindex);
      // AccessTree.rdataDescriptor.removeChildAt(Anode.parent(),draggedItemOfAccessTree,Sindex);
      //ExclusionTree.dataDescriptor.addChildAt(Enode.parent(),draggedItemOfAccessTree,Eindex);
      private function onExclusionListDragDrop( event:DragEvent ) : void
      var
      Eindex:Number = ExclusionTree.selectedIndex;
      var
      Sindex:Number = AccessTree.calculateDropIndex(event);
      XML;
      XML;
      if
      ((draggedItemOfExclusionTree.parent() != Enode.parent()) )
      ExclusionTree.removeChildAt(Eindex);
      AccessTree.addChildAt(dragItemExclusion, Sindex);
      // ExclusionTree.dataDescriptor.removeChildAt(Enode.parent(),draggedItemOfExclusionTree,Eind ex);
      // AccessTree.dataDescriptor.addChildAt(Anode.parent(),draggedItemOfExclusionTree,Eindex);
      private function onDragComplete( event:DragEvent ) : void
      AccessTree.selectedIndex = -1;
      ExclusionTree.selectedIndex = -1;
      private function clickHandler(event:Event):
      void
      var button:Button=event.target as
      Button;
      Alert.show(
      "Changes are saved"
      private function fetchMenuHandler(event:Event):
      void
      if(autoSuggest.text==""
      Alert.show(
      "Please select Role Name"
      else
      AccessTree.dataProvider=AccessListTreeData
      ExclusionTree.dataProvider=ExclusionListTreeData
      </mx:Script>
      <mx:Style>
      global
      font-family: Verdana;
      font-weight: normal;
      verticalGap: 0;
      horizontalGap: 0;
      padding-left: 0;
      padding-right: 0;
      padding-top: 0;
      padding-bottom: 0;
      FormHeading
      font-size: 10;
      </mx:Style>
      <mx:XMLList id="AccessListTreeData"
      <node label="GESS 1"
      <node label="Home"
      <node label="sdasd"
      </node>
      <node label="Human Resource">
      <node label="Personal"
      </node>
      <node label="Travel"
      <node label="Professional"
      <node label="Domestic Travel"
      <node label="international Travel"
      </node>
      </node>
      </mx:XMLList>
      <mx:XMLList id="ExclusionListTreeData"
      <node label="Menu"
      <node label="Menu 1"
      <node label="Sub Menu 1"
      <node label="Sub Menu 2"
      </node>
      <node label="Menu 2"
      </node>
      </node>
      </mx:XMLList>
      <mx:Label text="ADD ACCESS/DELETE ACCESS" fontSize="16" fontWeight="bold" y="10"
      <mx:Label text="Select Role" x="321" y="36" width="131" height="29" fontSize="15" fontWeight="bold"
      <mx:Form id="Role" height="124" x="307" y="73" width="316"
      <mx:FormItem fontSize="11" label="Role Name" required="true" fontWeight="bold"
      <comp:AutoCompleteModified id="autoSuggest
      width="
      155
      dataProvider="
      {data2}
      labelField="
      name
      </mx:FormItem>
      </mx:Form>
      <mx:Text x="267" y="205" width="138" height="20" fontSize="12" fontWeight="bold" text="Access List"
      <mx:Label x="578" y="205" height="20" width="114" fontSize="12" fontWeight="bold" text="Exclusion List"
      <mx:Button label="Save Changes" x="421.5" y="497" width="109.5" height="23" click="clickHandler(event)"
      <mx:Button id="addButton" label="Fetch Menu" click="fetchMenuHandler(event)" enabled="true" x="412" y="142" width="128"
      <mx:Tree id="AccessTree" labelField="@label
      width="
      197" height="246
      allowMultipleSelection="
      true
      dragEnabled="
      true
      dropEnabled="
      true
      dragMoveEnabled="
      true
      dragEnter="onAccessListDragEnter(event)"
      dragOver="onAccessListDragOver(event)"
      dragDrop="onAccessListDragDrop(event)"
      x="
      227" y="233"
      <mx:Tree id="ExclusionTree" labelField="@label
      width="
      205" height="248
      dropEnabled="
      true
      dragEnabled="
      true
      dragMoveEnabled="
      true
      dragEnter="onExclusionListDragEnter(event)"
      dragOver="onExclusionListDragOver(event)"
      dragDrop="onExclusionListDragDrop(event)"
      x="
      522" y="233
      </mx:Application>
