1 Reply Latest reply on Nov 5, 2009 6:14 PM by Ratsnackbar
    Need help making a function callable by multiple objects;
    MudkipsAreCool
      My code is below. My problem is that, while everything is fine and dandy for the first row of objects (checkbox, NumStepper, Textinput box), I am unable to change that function to work for the second row. How can I make it so that something like this could happen
      public function doAge(which:String):void
           if AgeInput(which)=
      Like that. It would be so easy to define a variable that could be plugged into one of the values, so that for the second row, the button could be
      click="doAge(Two)"
      So that the function would be repeated but instead of using AgeInputOne and PriceOne etc.. it would use AgeInputTwo and PriceTwo
      How would I go about doing something like this so that it is callable by each button?
      Here is my code, the indentation is a bit off because of the copy paste but you get the point:
      <mx:Application
      xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" borderStyle="outset"
      <mx:Script>
      <![CDATA[
      public var
      AgeGroup:String;
      public var
      Price:int;
      public function doAge():
      void
      if
      (AgeInputOne.value <= 12)
      AgeGroup =
      "Child"
      Price = 10;
      else if
      (AgeInputOne.value >= 13 && AgeInputOne.value <=18)
      AgeGroup =
      "Student"
      Price = 12;
      else if
      (AgeInputOne.value >= 18 && AgeInputOne.value <=64)
      AgeGroup =
      "Adult"
      Price = 15;
      else if
      (AgeInputOne.value >=65 && AgeInputOne.value <=98)
      AgeGroup =
      "Senior"
      Price = 8;
      else if
      (AgeInputOne.value >= 99)
      AgeGroup =
      "Cheater"
      Price = 9001;
      public function getPrice():
      void
      (PriceOne.text = String(Price))
      </mx:Script>
      <mx:Canvas x="38" y="30" width="836" height="414" borderStyle="outset" borderColor="#4999D0"
      <mx:CheckBox x="10" y="38" id="ShowOne"
      <mx:NumericStepper x="32" y="38" id="AgeInputOne" minimum="0" maximum="99" enabled="{ShowOne.selected}"
      <mx:Label x="123" y="38" text="$"
      <mx:TextInput id="PriceOne" x="136" y="38" width="68" editable="false
      enabled="
      {ShowOne.selected}"
      <mx:Button enabled="{ShowOne.selected}" click="doAge(), getPrice()" x="212" y="38" label="$$$" width="49"
      <mx:CheckBox x="10" y="68" id="ShowTwo"
      <mx:NumericStepper x="32" y="68" id="AgeInputTwo" minimum="0" maximum="99" enabled="{ShowTwo.selected}"
      <mx:Label x="123" y="68" text="$"
      <mx:TextInput id="PriceTwo" x="136" y="68" width="68" editable="false
      enabled="
      {ShowTwo.selected}"
      <mx:Button enabled="{ShowTwo.selected}" click="doAge(), getPrice()" x="212" y="68" label="$$$" width="49"
      </mx:Canvas>
      </mx:Application>
        • 1. Re: Need help making a function callable by multiple objects;
          Ratsnackbar Level 2
          I would break the Age functions into their own class (Perhaps called PersonData) with a setAgeGroup(age:uint) function which takes the age and sets an internal private varialbe stAgeGroup.  Then use a getAgeGroup():String function to get the age group.
          In the setAgeGroup() function test the age and change the stAgeGroup only when required.
          Use a different setPrice() and getPrice() function for the price within the same class or a different class.
          Make the getAgeGroup() and getPrice() bindable.
          Then on creation of the current class create two new PersonData instances.
          public var personData1:PersonData = new PersonData();
          public var personData2:PersonData = new PersonData();
          In the first numeric stepper on change call PersonData1.setAgeGroup(value);
          In the second call PersonData2.setAgeGroup(value);
          same deal for the price, however I would run those through a formatter and validator.
          Anything that needs to read the data can bind to the getAgeGroup() and getPrice() values using the change events.  Because the age group only changes when a particular age is input you will also have fewer events fired for that value.
          Not sure if that is entirely clear but I hope it helps.
          -Joe
