0 Replies Latest reply on Nov 5, 2009 7:39 AM by Carol L. Frampton
    [svn:fx-trunk] 11464: More fallout from switching from building textLayout. swc to using the one from TLF.
    Carol L. Frampton Level 2
      Revision: 11464
      Author:   cframpto@adobe.com
      Date:     2009-11-05 07:38:58 -0800 (Thu, 05 Nov 2009)
      Log Message:
      More fallout from switching from building textLayout.swc to using the one from TLF.  Remove build of textLayout rsl.
      For now I left textLayout in asdoc and fixed up the textLayout directories and added osmf so it would build.  Remove textLayout from framework build.
      I still need to submit the textLayout rsl once someone tells me what its filename should be.
      QE notes:
      Doc notes:
      Bugs:
      Reviewer:
      Tests run: ant asdoc now builds
      Is noteworthy for integration: no
      Modified Paths:
          flex/sdk/trunk/asdoc/build.xml
          flex/sdk/trunk/build.xml
          flex/sdk/trunk/frameworks/build_framework.xml
