0 Replies Latest reply on Nov 5, 2009 7:58 AM by Chet Haase
    [svn:fx-trunk] 11465: Fix for AnimateColor.
    Chet Haase Level 3
      Revision: 11465
      Author:   chaase@adobe.com
      Date:     2009-11-05 07:58:29 -0800 (Thu, 05 Nov 2009)
      Log Message:
      Fix for AnimateColor. When used in transitions, his effect only worked when operating on the default 'colorPropertyName' of "color". If you set a different colorPropertyName, it would ignore that property when detecting state changes. The fix was to return that property name from getAffectedProperties/getAffectedStyles so that the transitions machinery would detect changes to that property.
      QE notes: None
      Doc notes:  None
      Bugs:  sdk-24022
      Reviewer: Hans
      Tests run: checkintests, Mustella spark/effects/AnimateColor
      Is noteworthy for integration: No
      Ticket Links:
          http://bugs.adobe.com/jira/browse/sdk-24022
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/AnimateColor.as
