5 Replies Latest reply on Nov 9, 2009 7:02 PM by the_wine_snob
    export?
    kjetiltofte
      Two questions:
      Can I export/move/copy&paste one piece of a movie made in it's own project into another project?
      The "export" option in "File" never highlights so it can be choosen. Why?
      Thanks for any help.
        • 1. Re: export?
          That is now a function of Share/Personal Computer/DV-AVI.
          • 2. Re: export?
            Kodebuster Level 3
            If it's PE7 or lower, did you move the video to the Timeline ???
            If there's no video on the Timeline, then the Export function will be greyed out.
            If that's the ticket, be sure to check your Settings for Export before you proceed.
            If its PE8 then Export moved to Share as stated by Steve...
            • 3. Re: export?
              Hobby Guy Bill
              Are you sure?  I've had a case open with Adobe since 11/1/2009 and they continue to troubleshoot with me.  I was able to export using that method but if that's the case why is the option still under the File menu?  I have completely uninstalled versions 7 of the Elements Suite and reinstalled 8 with the same results.
              • 4. Re: export?
                kjetiltofte Level 1
                My current and only, first time, version is 8. And yes, "export" exists in the file meny.
                Anyway, It worked well exporting like instructed above.
                • 5. Re: export?
                  the_wine_snob Level 9
                  Great news. PrE has had issues with getting material from one Project, to another. In the past, only an add-on utility would help. PrPro did allow one to Copy/Paste between Sequences (think mini-Projects in a single Project), with some exceptions. Glad that PrE has finally come up with a cure.
