4 Replies Latest reply on Nov 9, 2009 7:08 AM by rjbull
    Type on text path VBScript CS2
    rjbull
      I am having issus with the FlipPathEffect property
      I can read the current valu but get an error when trying to set it.
      any suggestions?
      Here is part of my code
      Set myInDesign = CreateObject("InDesign.Application.CS2")
      myInDesign.Activate
      'open the template
      set myDocument = myInDesign.Open(theTemplateFolder & theTemplateName)
      Set myPage = myDocument.Pages.Item(1)
      set myTextFrame = myPage.TextFrames.item (frameToUse)
      Set myTextPath = myTextFrame.TextPaths.Add
      x = myTextPath.FlipPathEffect
      msgbox x
      myTextPath.FlipPathEffect 2036755568
      'myTextPath.Texts.FlipPathEffect  2036755568     '1852206192 not flipped
      myTextPath.Contents = theValue1
      msgbox x
      theFont = "Helvetica Neue LT Std 55 Roman"
      theSize = "5.5"
      myTextPath.Texts.Item(1).AppliedFont = theFont
      myTextPath.Texts.Item(1).PointSize = theSize
        • 1. Re: Type on text path VBScript CS2
          AdobeScripts Level 3
          msgbox x
          because this is Property:
          myTextPath.FlipPathEffect = 2036755568
          robin
          www.adobescripts.co.uk
          • 2. Re: Type on text path VBScript CS2
            rjbull Level 1
            Thanks for the suggestion but it still does not work for me.
            I am using CS2 is that the same version you are testing with?
            This still gives the same error. I have tried to set the flip to not flipped as well as flipped but get the same error.
            This is my code...
            'Set myTextPath = myTextFrame.TextPaths.Add
            Set myTextPath = myTextFrame.TextPaths.Item(1)
            '--add the text
            ' 2036755568 flipped
            msgbox "the flip it  " &  x
            myTextPath.FlipPathEffectidFlipValues.idFlipped = 1852206192
            myTextPath.Texts.FlipPathEffect.idFlipValues.idFlipped = 2036755568
            'myTextPath.Texts.Item(1).FlipPathEffect 2036755568                                                '2036755568 flipped  2036755568
            This is the error
            Windows Script Host
            Script: C:\Documents and Settings\rjbull\Desktop\InDesign_variable-curve5.vbs
            Line: 80
            Char: 1
            Error: Object doesn't support this property or method: 'myTextPath.FlipPathEffectidFlipValues'
            Code: 800A01B6
            Source:  Microsoft VBScript runtime error
            OK
            • 3. Re: Type on text path VBScript CS2
              This is the error
              Windows Script Host
              Line: 80
              Char: 1
              Code: 800A01B6
              the message error is very clear - you have error in line:
              you have joined two old lines ?
              what if you use exactly my line:
              myTextPath.FlipPathEffect = 1852206192
              robin
              • 4. Re: Type on text path VBScript CS2
                rjbull Level 1
                You are correct! It does work.
                I just had too much garbage from earlier attempts.
                Thanks.
