4 Replies Latest reply on Nov 6, 2009 12:41 AM by Harm Millaard
    Exported Interlaced MP4 Unplayable
    pftq
      I'm using the DV NTSC High Quality preset in Adobe Media Encoder CS4.  The export appears to go fine, but I have trouble playing the video.  The video looks very blocky and corrupt.  I've tried playing it in Media Player Classic and Windows Media Player using the K-Lite Codec pack.
      If I export with Progressive field order (no interlacing), the video plays fine.
      I've exported a few mp4 files in MPEG Streamclip using interlacing and they seem to play fine, so I don't think it's an issue with not having the right codec for playback.
      Is there something I should change in the export settings? Or is it just my computer not able to playback the files and if so, can I expect these MP4 files to play fine on other computers?
        • 1. Re: Exported Interlaced MP4 Unplayable
          Harm Millaard Level 7
          URGENT: Reformat your disk and do a clean install of OS & programs.
          Al-Qaida is better for your PC. That is the consequence of installing K-Lite or similar codec packages. Good luck. Hope you haven't attracted the Mexican flu in the process.
          • 2. Re: Exported Interlaced MP4 Unplayable
            pftq Level 1
            I was expecting that someone would bring that up, but I don't really see how that provides any solution.
            I've tried the videos on a number of computers and so far have not found any that were able to play the MP4s.  Basically, I want to be able to show the video on any other computer besides just the one I edit on - which is why I brought up the codecs (not sure how else you'd get the videos to play).  Is there something else that should be installed or is it a setting I need to change in the export? That's what I'm trying to ask here.
            • 3. Re: Exported Interlaced MP4 Unplayable
              Jim_Simon Level 8
              I've seen this myself.  The solution is to not export interlaced.  Since all computer monitors are progressive anyway, this is a very workable solution.
              • 4. Re: Exported Interlaced MP4 Unplayable
                You may be better off with exporting to Flash, since that is pretty common on most computers and give you the best compatibility on different systems.
