1 Reply Latest reply on Nov 6, 2009 6:34 AM by robdillon
    Converting 10 SWF
    LZupko
      How can I convert 10 ver. of swf to 8 version?
        • 1. Re: Converting 10 SWF
          robdillon Most Valuable Participant
          You're going to need the original .fla for each file. If the file is coded using AS3, then you'll have to first convert all of the code to AS2, which may or may not be possible. If the files are using AS2, then you can publish the file with the player setting set to player 8 and AS2.
