0 Replies Latest reply on Nov 5, 2009 3:53 PM by Darrell Loverin
    [svn:fx-trunk] 11482: Fix RTE when UIComponent.getFocus() is called an the application is not on the stage.
    Darrell Loverin Level 4
      Revision: 11482
      Author:   dloverin@adobe.com
      Date:     2009-11-05 15:53:32 -0800 (Thu, 05 Nov 2009)
      Log Message:
      projects/framework/src/mx/core/UIComponent.as
          Added null pointer check for sm.stage.
      projects/framework/src/mx/controls/SWFLoader.as
          Prevent loading the same swf twice when loadCompatibility is set and then SWFLoader.load() was called.
      QE notes: None.
      Doc notes: None.
      Bugs: SDK-24008
      Reviewer: Alex
      Tests run: checkintests, components/SWFLoader, MarshallPlan
      Is noteworthy for integration: No.
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-24008
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/SWFLoader.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/UIComponent.as
