0 Replies Latest reply on Nov 5, 2009 4:02 PM by Peter Farland
    [svn:fx-trunk] 11483: Adding a LRU cache for the transcoding results of a CFF based DefineFont4 tag to avoid transcoding the same font description twice .
    Peter Farland Level 3
      Revision: 11483
      Author:   pfarland@adobe.com
      Date:     2009-11-05 16:01:37 -0800 (Thu, 05 Nov 2009)
      Log Message:
      Adding a LRU cache for the transcoding results of a CFF based DefineFont4 tag to avoid transcoding the same font description twice.
      Also we now throw a better error when CFFFontManager is asked to embed a local font by name as this is not yet supported.
      QE notes: Please test that the same font embedded twice does not take twice as long as a single embedding.
      Doc notes: N/A
      Bugs:
      SDK-23966 - Compiler should generate a warning or error when embedAsCFF is true and src:local is used for font embedding
      SDK-23806 - OEM compiler appears to transcode embedded fonts twice
      SDK-23788 - Search fonts recursively
      Reviewer: Paul
      Tests run: Checkintests, bug test cases
      Is noteworthy for integration: Yes
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-23966
          http://bugs.adobe.com/jira/browse/SDK-23806
          http://bugs.adobe.com/jira/browse/SDK-23788
      Modified Paths:
          flex/sdk/trunk/lib/flex-fontkit.jar
          flex/sdk/trunk/modules/swfutils/src/java/flash/fonts/FontDescription.java
          flex/sdk/trunk/modules/swfutils/src/java/flash/swf/tags/DefineFont4.java
