6 Replies Latest reply on Nov 6, 2009 4:58 PM by artiescie
    noob: createPopUp, popup is clipped by parent??
    artiescie
      How do I avoid that clipping, I want a modal window that is bigger than the parent?
        • 1. Re: noob: createPopUp, popup is clipped by parent??
          Flex harUI Adobe Employee
          Popup shouldn't be clipped by parent unless it is bigger than the screen area.  It should be sized to its content.  Maybe you need to give it an explicit width/height.
          Alex Harui
          Flex SDK Developer
          Adobe Systems Inc.
          Blog: http://blogs.adobe.com/aharui
          • 2. Re: noob: createPopUp, popup is clipped by parent??
            artiescie Level 1
            3 files are all in same source directory
            Main.mxml
                <custom:ApplicationClass xmlns:mx="http://www.adobe.com/2006/mxml" xmlns:custom="*">
                <mx:VBox>
                    <mx:Button height="22" id="btnRecord" label="Record" width="77" x="64" y="45"/>
                </mx:VBox>
            </custom:ApplicationClass>
            ApplicationClass.as
            package
                import mx.core.WindowedApplication
                import flash.events.MouseEvent
                import mx.controls.Button
                import mx.events.FlexEvent
                import mx.managers.PopUpManager
                public class ApplicationClass extends WindowedApplication
                    // controls
                    public var btnRecord:Button;
                    public function ApplicationClass ()
                        addEventListener (FlexEvent.CREATION_COMPLETE, init);
                    private function init(e:FlexEvent):void
                        btnRecord.addEventListener(MouseEvent.CLICK, handleButton)
                            private function handleButton(e:MouseEvent):void
                        switch (e.target.label)
                            case  "Record":
                                var window:IFlexDisplayObject = PopUpManager.createPopUp(this, RecordClass, true)
            RecordClass.as
            package
                import mx.containers.TitleWindow
                public class RecordClass extends TitleWindow
                    public function RecordClass ()
                    public function init(event : FlexEvent ) : void
                        with (this) {
                            layout = "absolute";
                            width = 100
                            height = 100
                        start()
                    private function start():void
            Click Record, you see the small TitleWindow popup.  Drag it over the edge of parent window, it is clipped by parent window.
            Evidently I am overlooking some cause of that , can you help me out?
            tx
            artie
            • 3. Re: noob: createPopUp, popup is clipped by parent??
              PopUpManager is for handling popups within a NativeWindow in AIR.  You probably want to instantiate a new Window component.
              Alex Harui
              Flex SDK Developer
              Adobe Systems Inc.
              • 4. Re: noob: createPopUp, popup is clipped by parent??
                artiescie Level 1
                So what it adds up to is: there is no answer for the question ?
                i. .e to get modal window that is not clipped by it's parent.
                If I use PopupManager, I get clipping of my window.
                If I don't use PopupManager, I can't get a modal window.
                No way to have both ?
                tx
                Artie
                • 5. Re: noob: createPopUp, popup is clipped by parent??
                  There is no one function call to get both.  I think you can disable the Application when you open the new Window
                  Alex Harui
                  Flex SDK Developer
                  Adobe Systems Inc.
