0 Replies Latest reply on Nov 6, 2009 5:19 AM by CoreyRLucier
    [svn:fx-trunk] 11492: Checking in additional tweaks to SWC filtering when compatibility-version is used .
    CoreyRLucier Adobe Employee
      Revision: 11492
      Author:   clucier@adobe.com
      Date:     2009-11-06 05:18:44 -0800 (Fri, 06 Nov 2009)
      Log Message:
      Checking in additional tweaks to SWC filtering when compatibility-version is used.  Pushing the majority of thes
      e changes on behalf of Paul.
      QE notes: None
      Doc notes: None
      Bugs: None
      Reviewer: Paul
      Tests run: Checkin
      Is noteworthy for integration: No
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/sparkskins/build.xml
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/asdoc/AsDocAPI.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/common/CompilerConfiguration.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/common/MxmlConfiguration.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/SwcCache.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Compc.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/CompcPreLink.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Fcsh.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Mxmlc.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/PreLink.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/Application.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/Library.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools_en.properties
