6 Replies Latest reply on Nov 8, 2009 6:51 AM by virkof25
    Dragging a component to a Datagrid
    virkof25
      Hi Everyone
      I am trying to to create a Datagrid which allows me to drop a label or a botton to a particular cell of the grid. Any ideas how can I do that?
      At the moment whenever I try to drop a label to the Datagrid a new empty row is created.
      Thanks!
        • 1. Re: Dragging a component to a Datagrid
          salem_b_a Level 2
          i think you have to create your own item rendrer for datagrid rows!
          hope this helps
          Salem Ben Afia
          • 2. Re: Dragging a component to a Datagrid
            virkof25 Level 1
            Sorry, I don't understand what you mean.
            • 3. Re: Dragging a component to a Datagrid
              salem_b_a Level 2
              ok,
              your datagrid seems to miunderstand the components you want to drag because the default type is Text i think,
              so you have to change the item renderer of your rows:
              here is a sample from the "Tour de Flex" :
              <!-- Another example of an inline component used as the ItemRenderer-->
                          <mx:DataGridColumn>
                              <mx:itemRenderer>
                                  <mx:Component>
                                      <mx:VBox horizontalScrollPolicy="off" verticalScrollPolicy="off">
                                          <mx:CheckBox label="Triband" selected="{data.triband}"/>
                                          <mx:CheckBox label="Camera" selected="{data.camera}"/>
                                          <mx:CheckBox label="Video" selected="{data.video}"/>
                                      </mx:VBox>
                                  </mx:Component>
                              </mx:itemRenderer>
                         </mx:DataGridColum/>
              now this column will receive a custom component like this vbox,
              in your case if you want to fill the same column with diffrent components, i suggest you make a canvas with all the types of components you want to drag, in the same place (for example x=0, y=0) and when dragging select the one you want to fill,
              i can't explain so clear, but i suggest you paste your code, and will try together, else try to look on itemRendrer usage
              Salem
              • 4. Re: Dragging a component to a Datagrid
                virkof25 Level 1
                Thank you!!
                I  just copy that code to one of the columns to see how it works but it gives and error:
                "Could not resolve <mx:Component> to a component implementation> "
                • 5. Re: Dragging a component to a Datagrid
                  Gregory Lafrance Level 6
                  Check your code, or better yet post it here.
                  <mx:Component> must be inside the <mx:itemRenderer> tag.
                  If this post answered your question or helped, please mark it as such.
                  • 6. Re: Dragging a component to a Datagrid
                    virkof25 Level 1
                    Hi Greg,
                    This is the code. It stills gives me an error
                    <mx:DataGrid x="113" y="52" id="dataGrid" dropEnabled="true" creationComplete="dataGrid_creationCompleteHandler(event)" dataProvider="{getEmployeesResult.lastResult}" width="586" height="270" editable="false" variableRowHeight="true">
                              <mx:columns>
                                   <mx:DataGridColumn headerText="Staff" dataField="user_name" wordWrap="true" fontSize="12" fontWeight="bold" resizable="false" sortable="false"/>
                                   <mx:DataGridColumn headerText="Monday" dataField=""  />
                                   <mx:DataGridColumn headerText="Tuesday" dataField=""/>
                                   <mx:DataGridColumn headerText="Wednesday" dataField=""/>
                                   <mx:DataGridColumn headerText="Thursday" dataField=""/>
                                   <mx:DataGridColumn headerText="Friday" dataField=""/>
                                   <mx:DataGridColumn headerText="Saturday" dataField=""/>
                                   <mx:DataGridColumn headerText="Sunday" dataField=""/>
                                   <mx:DataGridColumn>
                                        <mx:itemRenderer>
                                             <mx:Component>
                                                  </mx:VBox>
                                             </mx:Component>
                                        </mx:itemRenderer>
                                   </mx:DataGridColumn>
                              </mx:columns>
                         </mx:DataGrid>
