6 Replies Latest reply on Feb 28, 2012 3:17 PM by flyingj481
      Hello everybody,
      I have seen the very nice connet cards produced from Presenter 7 - and I've two questions:
      a) I can't seem to get the hyperlinks/web links in ppt working in the presenter 7 published version - I'm sure it's something simple, as it seems everything else woks?
      b) does anyone know of any quick guides on putting a connet card together?
        • 1. Re: Hyperlinks
          Just spoke with technical support and they tell me that Presenter does not have the capability to handle hyperlinks to other documents/websites.  You can do this in Captivate, however.
          • 2. Re: Hyperlinks
            flyingj481 Adobe Community Professional (Moderator)
            Presenter does have the capability to handle hyperlinks, but they must either be a URL call (http://...) or a call to another location in the presentation. Hyperlinks to document will not work as local file path calls are not supported.
            PPT likes to put drop shadows on hyperlinks and Presenter will drop the link if there is a drop shadow on it, so be sure to double check that if a link isn't working.
            • 3. Re: Hyperlinks
              JPericich Level 1
              Actually, we tested it with the tech support person and was initially told that Presenter does not do hyperlinks.  Then they called me back and had me change the Global Flash Security Settings to allow access.  Once that was done my hyperlinks work now.
              • 4. Re: Hyperlinks
                Gotta love when tech support tells you the wrong answer first !
                • 5. Re: Hyperlinks
                  JPericich Level 1
                  Yeah, especially when I probably spent 4 hours or more trying different suggestions by everyone and trying to do further research.  It should be documented better.
                  • 6. Re: Hyperlinks
                    Ah, playing flash content locally opens all kinds of new issues, since it is intended to be delivered over the web, and it gets angry when you play it locally and attempt to link to the web. That makes sense. If you published the presentation to a webserver (Connect or otherwise), then you would likely not see the link disabled. FYI
