0 Replies Latest reply on Nov 6, 2009 11:38 AM by Carol L. Frampton
    [svn:fx-trunk] 11518: Add RET mx_internal flag batchTextInput which defaults to true.
    Carol L. Frampton Level 2
      Revision: 11518
      Author:   cframpto@adobe.com
      Date:     2009-11-06 11:38:42 -0800 (Fri, 06 Nov 2009)
      Log Message:
      Add RET mx_internal flag batchTextInput which defaults to true.  The TLF edit manager will batch all inserted text until the next enter frame event.  This includes text inserted via the GUI as well as api calls to EditManager.insertText().  Set this to false if you want every keystroke to be inserted into the text immediately which will result in a TextOperationEvent.CHANGE event for each character.
      QE notes:
      Doc notes:
      Bugs: editable combo box type-ahead feature won't work without this
      Reviewer: Gordon
      Tests run: checkintests, TextInput
      Is noteworthy for integration: no
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/RichEditableText.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/supportClasses/RichEditable TextEditManager.as
