0 Replies Latest reply on Nov 6, 2009 12:09 PM by kevinklin
    [svn:fx-trunk] 11525: halo to mx namespace change with backwards support for the halo namespace.
    kevinklin Adobe Employee
      Revision: 11525
      Author:   klin@adobe.com
      Date:     2009-11-06 12:09:36 -0800 (Fri, 06 Nov 2009)
      Log Message:
      I've renamed halo-manifest to mx-manifest, and renamed the namespace "library://ns.adobe.com/flex/halo" to "library://ns.adobe.com/flex/mx". In addition, the halo namespace is also mapped to the mx-manifest, which allows us to support both namespaces.
      Modified build files, css files, development applications, and certain skins to use the new mx namespace.
      This change required a small fix to the compiler to recognize both namespaces.
      QE notes: No
      Doc notes: Yes, you may update doc examples to use new mx namespace.
      Bugs: No
      Reviewer: Pete
      Tests run: checkintests, mustella compile
      Is noteworthy for integration: Yes, new mx namespace can be used.
      Modified Paths:
          flex/sdk/trunk/asdoc/build.xml
          flex/sdk/trunk/build.xml
          flex/sdk/trunk/development/eclipse/flex/airframework/.actionScriptProperties
          flex/sdk/trunk/development/eclipse/flex/framework/.actionScriptProperties
          flex/sdk/trunk/development/eclipse/flex/rpc/.actionScriptProperties
          flex/sdk/trunk/development/eclipse/flex/sparkTest/src/AddItemsTest.mxml
          flex/sdk/trunk/development/eclipse/flex/sparkTest/src/EffectsProperties.mxml
          flex/sdk/trunk/development/eclipse/flex/sparkTest/src/NewEffects.mxml
          flex/sdk/trunk/development/eclipse/flex/sparkTest/src/RemoveItemsTest.mxml
          flex/sdk/trunk/development/eclipse/flex/sparkTest/src/ScrollbarFrenzy.mxml
          flex/sdk/trunk/development/eclipse/flex/sparkTest/src/SkinTest.mxml
          flex/sdk/trunk/development/eclipse/flex/sparkTest/src/components/AnimationPropertiesForm. mxml
          flex/sdk/trunk/development/eclipse/flex/sparkTest/src/skins/CircularScrollBarSkin.mxml
          flex/sdk/trunk/development/eclipse/flex/sparkTest/src/skins/CircularScrollBarTrackSkin.mx ml
          flex/sdk/trunk/development/eclipse/flex/sparkTest/src/skins/MyScrollBarTrackSkin.mxml
          flex/sdk/trunk/development/eclipse/flex/sparkTest/src/skins/MyVScrollBarSkin.mxml
          flex/sdk/trunk/development/eclipse/flex/sparkTest/src/sparkTest.mxml
          flex/sdk/trunk/development/eclipse/flex/sparkTest/src/testWheel.mxml
          flex/sdk/trunk/frameworks/air-config.xml
          flex/sdk/trunk/frameworks/build_framework.xml
          flex/sdk/trunk/frameworks/flex-config.xml
          flex/sdk/trunk/frameworks/projects/airframework/build.xml
          flex/sdk/trunk/frameworks/projects/airframework/defaults.css
          flex/sdk/trunk/frameworks/projects/airframework/src/spark/skins/spark/windowChrome/MacTit leBarSkin.mxml
          flex/sdk/trunk/frameworks/projects/airframework/src/spark/skins/spark/windowChrome/TitleB arSkin.mxml
          flex/sdk/trunk/frameworks/projects/framework/build.xml
          flex/sdk/trunk/frameworks/projects/framework/defaults.css
          flex/sdk/trunk/frameworks/projects/halo/defaults.css
          flex/sdk/trunk/frameworks/projects/rpc/build.xml
          flex/sdk/trunk/frameworks/projects/spark/MXFTEText.css
          flex/sdk/trunk/frameworks/themes/AeonGraphical/AeonGraphical.css
          flex/sdk/trunk/frameworks/themes/Ice/Ice.css
          flex/sdk/trunk/frameworks/themes/Smoke/Smoke.css
          flex/sdk/trunk/frameworks/themes/Spark/spark.css
          flex/sdk/trunk/frameworks/themes/Wooden/Wooden.css
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/Grammar.jj
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/MXMLNamespaces.java
          flex/sdk/trunk/webapps/webtier/WEB-INF/flex/flex-config.xml
      Added Paths:
          flex/sdk/trunk/frameworks/mx-manifest.xml
          flex/sdk/trunk/frameworks/projects/airframework/mx-air-manifest.xml
      Removed Paths:
          flex/sdk/trunk/frameworks/halo-manifest.xml
          flex/sdk/trunk/frameworks/projects/airframework/halo-air-manifest.xml
