0 Replies Latest reply on Nov 6, 2009 12:52 PM by jmurphy67
    [svn:fx-trunk] 11526: modified the rsl target to accept a build number variable since we now need to accommodate build numbers for the external swcs we will be pulling into the sdk .
    jmurphy67 Level 1
      Revision: 11526
      Author:   jimurphy@adobe.com
      Date:     2009-11-06 12:52:33 -0800 (Fri, 06 Nov 2009)
      Log Message:
      modified the rsl target to accept a build number variable since we now need to accommodate build numbers for the external swcs we will be pulling into the sdk.  We want to use the build numbers provided instead of the sdk build number.
      I will also remove the RSL dir in svn as we will not need that place holder any longer
      There is a corresponding check in to my build directory that does the modifying of the config files to fix the various modes for the rsls
      QE notes: tests should start passing again
      Doc notes: no
      Bugs: no
      Reviewer:
      Tests run: checkintests
      Is noteworthy for integration: no
      Modified Paths:
          flex/sdk/trunk/build.xml
