0 Replies Latest reply on Nov 6, 2009 1:32 PM by Jason Szeto
    [svn:fx-trunk] 11532: ComboBox user interactions
    Jason Szeto Level 3
      Revision: 11532
      Author:   jszeto@adobe.com
      Date:     2009-11-06 13:32:37 -0800 (Fri, 06 Nov 2009)
      Log Message:
      Added support for an improved user interaction. When the user starts typing in the textInput, ComboBox will now update the textInput with the rest of the matching item. It will then select the non-typed text. When using the navigation keys, the textInput will change to the new highlighted item.
      QE notes: Tests need updating to account for new user interaction
      Doc notes: We should update the docs to describe the user interaction
      Bugs: N/A
      Reviewer: Glenn
      Tests run: DropDownList, ComboBox
      Is noteworthy for integration: No
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/ComboBox.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/DropDownList.as
