0 Replies Latest reply on Nov 6, 2009 2:29 PM by jmurphy67
    [svn:fx-trunk] 11541: Fix the textLayout build number that is set in the main build. xml to match what will be set when the build machine does NOT do the build
    jmurphy67 Level 1
      Revision: 11541
      Author:   jimurphy@adobe.com
      Date:     2009-11-06 14:29:41 -0800 (Fri, 06 Nov 2009)
      Log Message:
      Fix the textLayout build number that is set in the main build.xml to match what will be set when the build machine does NOT do the build
      QE notes: no
      Doc notes: no
      Bugs: no
      Reviewer:
      Tests run: checkintests
      Is noteworthy for integration: no
      Modified Paths:
          flex/sdk/trunk/frameworks/air-config.xml
          flex/sdk/trunk/frameworks/flex-config.xml
