Good morning, Brock
For the Click Box, you need to edit the properties and enable
the feedback captions. Enable the Hint caption if you want to hear
a sound play when hovering the Click Box. Enable the Success
caption if you want the sound to play after clicking the Click Box.
Then you edit the caption and assign audio there.
For mouseovers, add a Rollover Caption or Rollover Image.
This provides two areas on the slide. One is the area you mouse
over, while the other is the area that appears. You then edit the
area that appears and add audio to that area.
Hopefully this helps... Rick
