3 Replies Latest reply on Nov 7, 2009 4:41 AM by Shivik
    Populate ComboBox from RemoteObject data
    Shivik Level 1
      Hello all
      I am trying to use RemoteObject for populating a combobox. Here's my value object and mxml code....
      // Value Object Class: dataVO.as
      package com.mycomp
           [RemoteClass(alias="datavO")]
           [Bindable]
           public class dataVO {
                public var data_id:int;
                public var data_name:String;
                public var data_type:String;
      // ActionScript code
      private
      function getAuthors(event:Event):void
           // setup the remoteobject here
           serviceRO.getData.addEventListener(ResultEvent.RESULT, resultListener);
      private function resultListener(event:Event):void
           dgrid1.dataProvider = event.result as Array; // works perfectly
           combo1.dataProvider = event.result.data_name as Array; // displays empty combobox
      <!-- MXML Code -->
      <mx:ComboBox id="combo1" /> <!-- I want to populate names here -->
      <mx:DataGrid id="dgrid1" />
      How should I do this?
      Thanks and Regards
      ShiVik
        • 1. Re: Populate ComboBox from RemoteObject data
          Shivik Level 1
          I am happy for now. I found out that this can be done by using the property labelField
          private
               combo1.dataProvider = event.result;
               combo1.labelField = "data_name";
          <!-- MXML Code -->
          What about the dataField however? What if I want to setup some event on the selection of comboBox, which I will have to eventually.
          • 2. Re: Populate ComboBox from RemoteObject data
            salem_b_a
            i faced this problem somewhere, all i remember is that the array of variables was saved on the event.result[0].
            i didn't really understand why, but that worked for me.
            you may try event.result[0].data_name
            else you will have to run throught the result manually, and make your own data_name array.
            Try to debug and see the result structure.
            Hope this helps,
            Salem
            • 3. Re: Populate ComboBox from RemoteObject data
              Shivik Level 1
              Yes Salem.You are right.
              Indeed that's what I also found while trying to use the selectedItem property. It displays the RemoteObject for that particular row.
              I made use of the same to get what I wanted....
              private function onChange(event:ListEvent):void {
                   Alert.show(combo1.selectedItem.data_name);
              Thanks and Regards
              ShiVik
