1 Reply Latest reply: Nov 9, 2009 12:05 PM by Chris Cox RSS
    Flash panels crashing Photoshop CS4
    Harald Heim
      Flash panels crash Photoshop CS4 under the following conditions:
      1. The "Auto-Collapse Iconic Panels" option is activated under Edit > Preferences > Interface.
      2. The flash panel is collapsed to an icon.
      3. You click on the panel icon to display it and run a filter plugin from the flash panel.
      The crash happens when you run the filter plugin from the panel or after you click OK on the plugin dialog. Sometimes the crash happens after the plugin was applied and you do something else in Photoshop.
      I was able to reproduce the problem with my own ThePluginSite panel and the Blow-Up panel of Alienskin.
      If the "Auto-Collapse Iconic Panels" option is deactivated, there is no crash.
      Can this problem be fixed in Version 11.02 of Photoshop CS4?
