Expand my Community achievements bar.
Getting Error using secure https, while its working with http urls
Avatar
Level 1
Hi Helper,
I am using both amf &
amfsecure
I defined my servlet-config.xml properly and also added the custom channel in my AC
var ch1:SecureAMFChannel = new SecureAMFChannel("my-secure-amf", "https://xxxxxxx/messagebroker/amfsecure");
var channelSet:ChannelSet = new ChannelSet();
channelSet.addChannel(ch1);
then i set this channel set to my service.
When i run the application and try to access the remote service method nothing happens and after a min or so exception comes that not able to make the connection.
The error:
channelSet = (mx.messaging::ChannelSet)#6
              clientId = (null)
              connected = false
              defaultHeaders = (null)
              destination = "RFWFlexTreeTableDataService"
              id = "0E18136A-CC9E-0C3A-7A8D-D4988264426C"
              reconnectAttempts = 0
              reconnectInterval = 0
              requestTimeout = -1
              subtopic = ""
      connected = false
      connectTimeout = -1
      enableSmallMessages = true
      endpoint = "https://xxxx/messagebroker/amfsecure"
      failoverURIs = (Array)#11
      id = "my-secure-amf"
      mpiEnabled = false
      netConnection = (flash.net::NetConnection)#12
        client = (mx.messaging.channels::SecureAMFChannel)#4
        connected = false
        objectEncoding = 3
        proxyType = "none"
        uri = "https://xxxx/messagebroker/amfsecure"
      piggybackingEnabled = false
      polling = false
      pollingEnabled = false
      pollingInterval = 3000
      protocol = "https"
      reconnecting = false
      recordMessageSizes = false
      recordMessageTimes = false
When trying to run https://xxxx/messagebroker/amfsecure to test the messagebroker, it works fine.
In addition,I can use normal AMFChannel and it worked fine for me to access the remote services.
Only issue I am facing is with SecureAMFChannel.
What am I doing wrong?
Does using SSL related to this problem.
Please please advise
Jo
1 Reply
Avatar
Level 1
I resolved the issue
The missing part was adding flex-tomcat-common.jar in lib directory
and making sure we use amfsecure
